Two subs for 2ch HIFI : Stereo or Mono ?
Discuss Two subs for 2ch HIFI : Stereo or Mono ? in the Equalization | Calibration forum; Two subs for 2ch HIFI : Stereo or Mono ? Hi Guys, Soon ill be getting my new subs and was planning on using them for both HT and 2ch ...
Views: 166 - Replies: 10
Old 10-31-09, 07:22 PM   #1
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
  Drizt is online now
Question Two subs for 2ch HIFI : Stereo or Mono ?
Hi Guys,
Soon ill be getting my new subs and was planning on using them for both HT and 2ch HIFI use. Im wondering if people go the stereo bass or mono bass option?
For a bit of background information my active speakers have a selectable low pass output crossover point of 40Hz. Would people normally go for a mono setup or stereo with two subs? I know I can try this out for myself when they arrive and I work out what electronics to use, but thought I would ask the question anyways.
Old 10-31-09, 07:25 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Two subs for 2ch HIFI : Stereo or Mono ?
Generally the bass information thats recorded is not stereo so a mono feed will be fine, is the receiver that your using have a dedicated sub output?
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 10-31-09, 07:32 PM   #3
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
  Drizt is online now
Yeap, I have an Integra DHC-9.9.
Old 10-31-09, 07:39 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Ok then it wont matter just use the sub output and your good to go as it will automatically send the lows from both channels to the sub.
Home theater:
Two Channel system:
My Webpage
Old 10-31-09, 07:57 PM   #5
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
  Drizt is online now
Depends on how well the Integra implements the crossovers. I can certainly test it out.
Old 10-31-09, 08:03 PM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
If its anything like my Onkyo 805 then it will do a great job.
Home theater:
Two Channel system:
My Webpage
Old 10-31-09, 10:00 PM   #7
Alias: David
Mika75's Avatar
Loc: Victoria, Australia
User: #33426
Since: Feb 2009
  Mika75 is offline
I have tried both, Mono Bass is louder because it's output is summed (this is from my own experience and from research around the net)
To me Stereo Sub Bass sounds much more realistic/accurate. I xover @ 100hz... subs are individually positioned approx 1m directly behind main L/R
I'm guessing u will be driving the subs from the active loudspeakers internal xover, and if so is 40 hz the only option? I can try it @ 40hz and let u know my finding's if u like Dritz?
(& trust me there is separation down there, replaying both Music & Movies & watching signal indicators on the amp it's easily noticeable )
Pre: TAS Processor Eq: DCX 2496 Power: Behringer A500, Ebony 290w x4 Source: Sony DVD Front: Tag 2.6 Center: n/a Rear: Yamaha NS-225 Subs: Whise 624
Old 11-01-09, 02:11 AM   #8
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
  Drizt is online now
Cheers mate. Always happy to hear about peoples findings.
Thanks for the reply.
Old 11-01-09, 03:28 AM   #9
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
  Drizt is online now
Question Re: Two subs for 2ch HIFI : Stereo or Mono ?
I downloaded the DCX software to have a play with it. Seems to have all that is required. Seems like a great little unit.
I did read that it works better when fed pro levels. And that the Behringer MX882 would be a great unit to do any mixing (combing L + LFE & R + LFE etc.) as well as up'ing the levels to met the pro level requirements.
Thoughts?
Old 11-01-09, 04:23 AM   #10
Alias: David
Mika75's Avatar
User: #33426
Since: Feb 2009
  Mika75 is offline
I also downloaded the software, more out of curiosity, but never used it.
The DCX GUI is intimidating at 1st, but becomes very simple once initial settings are stored.
re:works better when fed pro levels It's designed to drive pro gear not consumer, I don't have issues as I use a pro amp with input trim pots, but u may end up with noise if the amplifier ur driving has high input levels, & these will need to be attenuated.
Old 11-01-09, 05:00 AM   #11
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
  Drizt is online now
I heard that it was the input levels that need to be at pro level? The Quest 3004 can accommodate both pro and consumer levels as far as I could tell from the manual. If it can't the MX882 could be used to up the levels on the way in to the DCX and then drop them back down after the DCX before the going on to the amps. Many options there. That behringer gear seems to offer a lot of options for comparatively low prices.
hifi, mono, stereo, subs
