| BFD | Electronic Equalization Devices Bleedthrough from engine L to engine R?Discuss Bleedthrough from engine L to engine R? in the Equalization | Calibration forum; Bleedthrough from engine L to engine R? Hi: I have a DSP1124P and I am using Engine Left (inputs/outputs#1) for use with my sub being fed from ... |
Views: 586 - Replies: 6
| Bleedthrough from engine L to engine R? Hi: I have a DSP1124P and I am using Engine Left (inputs/outputs#1) for use with my sub being fed from my sub-out on my A/V receiver,Engine Right(inputs/outputs) for use with my integrated amp, used for only two-channel.That's two different set-ups, with one sub doing double duty. My question(s) concerns the use of the top right button(IN/OUT)! Should this be OFF when I want to compare between "filtered" and "unfiltered" information which is programmed into the BFD, or should it be "flashing"? Seems to me that either position (flashing or off), I can't tell much of a difference! I am only using 4 filters for two-channel (Engine R), so maybe that's why I can't notice much, but when I switch to Engine L, which is my A/v receiver(only movies),using 8 filters here, I should be able to hear a differnce?! Also I get some "bleedthrough" between engines. with Engine L light "off" and my receiver "off",when I switch from Engine R (which I am using for music) and switch to Engine L, which should not output anything because the receiver is "off"for this engine, my sub still operates! Are you confused yet! I am trying to compare between "filtered and "unfiltered" info on both engines but not much luck! Hope you can understand this rather long post?! Thanks for any help! Huck ![]() | ||||
| | #2 | ||||||
| Re: Bleedthrough from engine L to engine R? Quote:
Off is filters dis-engaged, with LED's monitoring the ouput signal. Flashing is total bypass mode, with LED's monitoring the input signal. Quote:
brucek | ||||||
| | #3 | |||||
| | #4 | |||||
The spec tells you how far below a full scale signal the offending voltage is on the opposite channel. In this case it's 76dB down. I converted that to voltage so it might be more meaningful to you. It's the nature of the device. Nothing you can do about it. brucek | |||||
| | #5 | |||||
| | #6 | |||||
I think the only complaint is that it has only one program, although it also has 40 filters.... brucek | |||||
