Eliminated the dreaded BFD hum for free
Discuss Eliminated the dreaded BFD hum for free in the Equalization | Calibration forum; Eliminated the dreaded BFD hum for free For years I've been able to get rid of ground loop hums in my system by simply attaching a piece ...
Views: 1012 - Replies: 4
Old 11-11-06, 07:27 PM   #1
Legairre
Inactive
Alias:
User: #
Posts: n/a
For years I've been able to get rid of ground loop hums in my system by simply attaching a piece of speaker wire to the chasis of one piece of gear to another. In the case of the BFD there's a siliver grounding screw underneath the unit right in the middle. All I did was attach a piece of speaker wire from the BFD's grounding screw to a screw on the chasis of my pre amp and the hum is gone.
Legairre
Old 11-12-06, 07:02 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Eliminated the dreaded BFD hum for free
Wow, great information, Legairre! Hopefully it’ ll work for other folks, too.
Old 11-13-06, 03:34 AM   #3
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
Interesting information.
When I tried to add a Behringer mixer to my system the case had a high electrical potential.
My wife was dusting the rack and had a shock from the case.
A neon test screwdriver showed a distinct glow.
This was prior to any ICs being fitted.
I just switched it on to see the usual Behringer light show.
Reversing the 2-pin plug in the mains socket solved the problem.
Behringer mains plugs are 2-pin in Scandinavia.
They are also 90 degree offset so they usually follow a pattern in the multiplug.
This one doesn't.
I wonder whether I should take the mixer back? I haven't even used it yet.
I have never suffered from hum though.
Old 11-13-06, 08:12 AM   #4
Alias: brucek
User: #6
  brucek is offline
Yeah, I think low current devices in most of europe etc use a 230volts/50Hz unearthed two wire system.
The plug is called a europlug I believe. Looks like this?:
If you swap hot and neutral and the problem goes away, then you have a leaky device in the behringer, and I would indeed return it.....
Old 11-13-06, 05:25 PM   #5
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
brucek wrote: View Post
Yes, something like that.
Thanks for the advice brucek. I shall return it.
