Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > BFD | Electronic Equalization Devices
  Discuss Two different subs co-located- same frequncy response - possible? in the Equalization | Calibration forum; Two different subs co-located- same frequncy response - possible? I co-located a BIC h100sub and a new eD sub and found that the frequency response mirrored each other exactly. ...
Views: 999 - Replies: 16
Old 11-29-06, 07:54 PM   #1
Alias: Bones
User: #2727
Since: Sep 2006
  tdamocles is offline
I co-located a BIC h100sub and a new eD sub and found that the frequency response mirrored each other exactly. Is this possible because of room acoustics?
Old 11-29-06, 07:56 PM   #2
Alias: Bones
User: #2727
Since: Sep 2006
Re: Two different subs co-located- same frequncy respone - possible?
Wow...I should proof read my stuff....
Old 11-29-06, 11:25 PM   #3
Owner
Loc: L.A. (Lower Bama)
Re: Two different subs co-located- same frequncy response - possible?
I would say it is very possible and probable. I symmetrically located my two SVS subs in the front corners of my room and got exact response out of both of those.
Old 11-30-06, 04:27 PM   #4
Alias: Bones
User: #2727
Since: Sep 2006
On both graphs the the FR takes a dive at 20hz identically... Is there some sort of subsonic filter on the BFD? Could this be room acoustics screwing with the response?
Old 11-30-06, 04:38 PM   #5
Alias: brucek
User: #6
  brucek is offline
What is the low end response of your two subs?
No
Old 11-30-06, 05:50 PM   #6
Alias: Bones
User: #2727
Since: Sep 2006
brucek wrote: View Post
No
The subs are stacked. The h100 is on top of the eD. The H100 is front firing/rear port and the eD is bottom firing/rear port. They were both plumbed through the BFD in the bypass mode when these tests were taken. The first is the h100 and the second is the eD. Any comments?
Old 11-30-06, 06:00 PM   #7
Alias: Bones
User: #2727
Since: Sep 2006
Not quite identical but close....
The H100 stated specs are 24hz(+-3db)- ?
The eD stated specs are 18hz(+-3db)- ?
Old 11-30-06, 06:25 PM   #8
Alias: brucek
User: #6
  brucek is offline
Did you do your response checks with each sub independently. (one off and the other on)?
Is the stack in a corner?
The response of the H100 seems normal, but the other should be a bit better in the bottom end I would think.
Old 11-30-06, 06:29 PM   #9
Alias: Bones
User: #2727
Since: Sep 2006
Both are stacked in a corner and were tested independently. Seems odd that the FR follows a crossover of 80hz when I have all crossovers disabled.
Old 11-30-06, 06:52 PM   #10
Alias: brucek
User: #6
  brucek is offline
Why is that? Normally you measure with the crossover enabled...
Can you expand on your reason or expectation for using two subs - one of which has a lesser response than the other?
Bookmark and Share
Dish Network
