HELP please 1124p
Discuss HELP please 1124p in the Equalization | Calibration forum; HELP please 1124p Hi everyone I need help just got this dsp 1124 and need help setting it up to my 1646 svs ...
Views: 602 - Replies: 4
Old 12-17-06, 11:25 PM   #1
Alias: randy
Loc: chicago IL
User: #4768
Since: Dec 2006
  randyman is offline
HELP please 1124p
Hi everyone
I need help just got this dsp 1124 and need help setting it up to my 1646 svs sub ?????
please anybody??????????????????
thanks
Randyman
Old 12-17-06, 11:36 PM   #2
Alias: Mitch
Loc: Naperville, Illinois
User: #2469
Since: Sep 2006
  Mitch G is offline
Re: HELP please 1124p
Have you used REW to do sweeps of your room and figure out what filters you need?
If not, then it might be difficult to figure out exactly how you need to program the BFD.
Also, have you looked at the BFD guide: http://www.hometheatershack.com/forums/bfdguide/
Finally, can you explain a bit more about what it is you are having problems with?
Mitch
Old 12-17-06, 11:42 PM   #3
Alias: Mitch
User: #2469
Since: Sep 2006
  Mitch G is offline
Oh, I just re-read your post. Are you trying to figure out how to connect it to the sub?
Basically, you need two cables with an RCA connector on one end and a mono phone plug on the other.
One cable goes between the receiver (subwoofer output) and the BFD (input). The other cable goes from the BFD (output) to the subwoofer input.
I once had the same question. This thread might help: http://www.hometheatershack.com/foru...where-buy.html
Mitch
Old 12-18-06, 10:04 AM   #4
Alias: randy
Loc: chicago IL
User: #4768
Since: Dec 2006
  randyman is offline
Hi Mitch
I know how to hook it up Im just having problems setting it up this is all new to me if you guys could point me in the right direction that would be great ??
Thanks again
Randy
Old 12-18-06, 10:23 AM   #5
Alias: brucek
User: #6
  brucek is offline
First read THE BFD GUIDE
Then read the REW HELP FILES
