| BFD | Electronic Equalization Devices XLR or 1/4" to RCA CablesDiscuss XLR or 1/4" to RCA Cables in the Equalization | Calibration forum; XLR or 1/4" to RCA Cables The BFD guide recommends getting cables that go from RCA to 1/4 or XLR plugs instead of using adaptors from ... |
Views: 943 - Replies: 7
| XLR or 1/4" to RCA Cables The BFD guide recommends getting cables that go from RCA to 1/4 or XLR plugs instead of using adaptors from Radio Shack, or elsewhere. Anyone have a good source for these cables? Is there any reason to prefer XLR over 1/4", or vice versa? | ||||
| | #3 | ||||
| Re: XLR or 1/4" to RCA Cables I prefer the look, positive fit and locking mechanism of the XLR. However, I don't think there is any technical reason that one would sound or perform better than the other. -- Otto | ||||
| | #4 | ||||
| Re: XLR or 1/4" to RCA Cables I had bluejeancables.com build some 1/4" to RCA for me and they were very reasonable... nothing real fancy. I believe apature.com will build some as well and they are very reasonable. | ||||
| | #6 | ||||
| Re: XLR or 1/4" to RCA Cables Hopefully you're aware of the midi issue with the BFD. Maybe your unit has the new software.. brucek | ||||
| | #7 | ||||
| Re: XLR or 1/4" to RCA Cables Yeah. I was reading that this morning. I'm going to check the version this evening. I have other uses for the MIDI-USB cable - so it isn't a total loss if the issue isn't ever resolved. | ||||
| | #8 | ||||
| Re: XLR or 1/4" to RCA Cables Checked the version. I also have 1.3 -- bummer. | ||||
