| BFD | Electronic Equalization Devices Phase problem? Will an EQ help?Discuss Phase problem? Will an EQ help? in the Equalization | Calibration forum; Phase problem? Will an EQ help? Subwoofer crossover is set to 80Hz. Subwoofer has switchable 0/180 phase control.
The graph on the left with phase set ... |
Views: 772 - Replies: 12
| Phase problem? Will an EQ help? Subwoofer crossover is set to 80Hz. Subwoofer has switchable 0/180 phase control. The graph on the left with phase set to 180 shows a steep valley at 70Hz, while the graph on the right with phase set to 0 shows a steep valley at 87Hz. Which is the more appropriate setting, 0 or 180? And is there anything a BFD could do to help? Thanks, Ron Last edited by RonLF; 01-05-07 at 04:23 PM.. | ||||
| | #4 | ||||
| Re: Phase problem? Will an EQ help? Those narrow spikey dips won't be audible. I don't think you need to address them at all. The BFD is used with wide peaks associated with room resonances. Why not post your response from 15Hz to 200Hz with a vertical resolution of 45dB to 105dB and let us have a look.... brucek | ||||
| | #5 | |||||
| Re: Phase problem? Will an EQ help? Quote:
Are you sure that hole at 69-70Hz won't be audible? I listen to a lot of classical music. I just put the cables and SPL meter away (I run 50 foot cables from my computer to my HT), but I'll post the other graphs tomorrow. The response below 50Hz was pretty good -- around 72-75dB from 30-60Hz, with 15-30Hz in the 75-80dB range. I'm using the Radio Shack SPL meter (with appropriate correction file) so I figured the results below 30Hz probably weren't very accurate. I do have another dip around 175Hz. The room has plaster walls and wooden floors (with an area rug), so I know my response will never be perfect. | |||||
| | #6 | |||||
You didn't post your 15Hz to 200Hz response...... brucek | |||||
| | #7 | ||||
| Re: Phase problem? Will an EQ help? Try changing the subwoofer distance setting in your AVR, this will adust the phase in small increments, it might give a better result than the 0deg and 180deg sttings. | ||||
| | #8 | |||||
| | #9 | ||||
| Re: Phase problem? Will an EQ help? Are your mains set to large or small? -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | ||||
| | #11 | |||||
Also, how high off the floor is the mic when you're doing these measurements? And how far are the mains and subwoofer from the walls? Distances around 4 feet would correlate to the 70Hz dip and distances around 3 feet would be 88Hz. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" Last edited by DrWho; 01-09-07 at 12:43 AM.. | |||||
| | #12 | |||||
I was able to fill a similar notch by juggling that and sub gain... | |||||
| | #13 | ||||
| Re: Phase problem? Will an EQ help? Right, if set to large, the subwoofer won't get used with a pure stereo signal. The situation where both subwoofer and mains get the absolute same signal is if your receiver sets the bass output to BOTH (or something similar) and you are playing back the LFE channel. Large implies no crossover in use. I believe the 70Hz dip is common in many rooms because that's the room height of 8', and your head is usually about half and half. If I'm remembering things correctly. Doesn't really matter where the speakers are for that dip. But since changing the crossover point reduced the dip, looks like phase is contributing to it. | ||||
