DSP1124P gain? M-Audio Uno gotcha
Discuss DSP1124P gain? M-Audio Uno gotcha in the Equalization | Calibration forum; DSP1124P gain? M-Audio Uno gotcha I took advantage of BFD research done here to avoid MIDI hassles by buying a used unit (Date Code 0801, ...
Views: 674 - Replies: 3
Old 01-20-07, 05:51 PM   #1
Alias: blekenbleu
Loc: Lexington, KY
User: #5329
Since: Jan 2007
  blekenbleu is offline
I took advantage of BFD research done here to avoid MIDI hassles by buying a used unit (Date Code 0801, firmware 1.0).
I thought I had outsmarted myself when first trying to program filters using REW and an M-Audio Uno USB-to-MIDI dongle,
but M-Audio labeled its MIDI connectors "backwards": IN must be connected to BFD IN.
My computer speakers are pair of Altec 19s and Def Tech PF 12 sub,
and I decided to play and learn with Internet resources available before trundling stuff to the home theater.
I simply inserted the BFD between headphone out and CD in, so got full-range response instead of just subwoofer,
but had good success flattening response between 26 and 80Hz.
I am using the built-in Sigma Tel headphone/microphone sound in a Dell D520 laptop with external attenuation and DC decoupling for an old RS 33-2050;
I decided to check the loop-back frequency response of the sound card and
BFD and was surprised to discover that BFD output is over 10x input.
This is with filters bypassed, monaural 1/4 phone plugs into the BFD to force its balanced in and out to unbalanced.
To compensate, I added an additional 12:1 attenuation for the 1/4 jack on my laptop mic input kludge.
I found nothing in Behringer's specifications or the FAQ here to suggest that BFDs have other than unity nominal gain.... did I miss something?
Old 01-20-07, 06:18 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: DSP1124P gain? M-Audio Uno gotcha
Nope, it's unity gain with no filters selected. I have checked it several times myself.
Best way to check this is to do a full range frequency response of a couple cables connected together between line-out and line-in of the soundcard, with the mic cal cleared and C-weight unchecked, and the soundcard file loaded. The response chart will of course be a flat line at the target level you have set up.
Now, without changing any levels in REW, breakout the cables where you have them connected together and insert the BFD. The graph in REW will show the response of the BFD. It will also show that the level is the same as with the cable response. Unity gain (actually I show about a 0.5db loss through my BFD as shown in the plots below.....
Name:  bfd vs cable.jpg
Old 01-21-07, 08:37 AM   #3
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
The gain is in your soundcard's mic input, you need to use a line input.
Old 01-21-07, 01:21 PM   #4
Alias: blekenbleu
Loc: Lexington, KY
User: #5329
Since: Jan 2007
JohnM wrote: View Post
I found my error; the attenuator that I cobbled together uses shorting RCA sockets;
unplugging the RCA line (SPL meter) input shorts the 82K resistor for the 82+10k MIC voltage divider,
so I had added a separate 51+4.7k voltage divider (which I erroneously thought was cascaded)
for the 1/4 phone jack input from the BFD... Doh!
