Can I put my BFD at the sub?
Discuss Can I put my BFD at the sub? in the Equalization | Calibration forum; Can I put my BFD at the sub? Because of all its bright lights and so forth, I was thinking I would just put my BFD by my ...
Views: 619 - Replies: 2
Old 01-24-07, 09:34 AM   #1
Alias: lovingdvd
User: #5942
Since: Jan 2007
  lovingdvd is offline
Because of all its bright lights and so forth, I was thinking I would just put my BFD by my sub rather than in the equipment rack. The sub is behind the couch. Since the BDF just takes the sub in and gives a sub out, this seems totally doable. I just wanted to ask to make sure I'm not overlooking anything, as I haven't seen anyone else mention they've done this. Thanks.
Old 01-24-07, 10:19 AM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: Can I put my BFD at the sub?
It really shouldn't matter where you put the BFD. For longer runs, I might suggest using the balanced input if you can. If not, it'll probably be fine with an RCA cable and adapters.
-- Otto
Old 01-24-07, 12:13 PM   #3
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
Yeah, under the couch, whatever. I have mine underneath the bookshelf to the right of my TV stand. My TV stand and flanking bookshelf cabinets have legs, so I have clearance underneath for my power bars, router, etc.
It's not totally in view, but I can still see the level meter so I know if I'm clipping, how loud the bass signal is, etc.
