| BFD | Electronic Equalization Devices Will my new BFD DSP1124P definitely not work with MIDI?Discuss Will my new BFD DSP1124P definitely not work with MIDI? in the Equalization | Calibration forum; Will my new BFD DSP1124P definitely not work with MIDI? Today I picked up the DSP1124P from a local retailer. Its likely been sitting there for several weeks if not ... |
Views: 750 - Replies: 7
| Will my new BFD DSP1124P definitely not work with MIDI? Today I picked up the DSP1124P from a local retailer. Its likely been sitting there for several weeks if not months, so I'm sure it wouldn't already have the 1.4 firmware. My question is whether there is any chance the MIDI part will work so that I can use REW to send the programming to the device. Any one know? For instance does this issue affect ALL 1.3 firmware units made say over the past year? And what does the bug prevent me from doing exactly? Does it just disable a few functions or will REW not be able to talk to it at all? Thanks. | ||||
| | #2 | ||||
| Re: Will my new BFD DSP1124P definitely not work with MIDI? Unless Behringer has made some changes in the last month of so, you can be sure the MIDI won’t work. See this thread, and a link to a second important one at the end of the last page. Regards, Wayne | ||||
| | #4 | ||||
| Re: Will my new BFD DSP1124P definitely not work with MIDI? Too bad. Well, while I await the chip I may try manually storing the info into the BFD. Hopefully that's not too much of a PITA... | ||||
| | #5 | |||||
| Re: Will my new BFD DSP1124P definitely not work with MIDI? Quote:
brucek | |||||
| | #6 | |||||
I was just thinking that the MIDI programming would be a real time saver during the experimental period. My impression is that it'll take several interactions and experimentation to get the curve down nicely. How good of a predictor is REW in this sense? In other words once it makes its recommendations is there generally a lot of touch up or are they spot on? My understanding is that it will show a red line that shows what it expects the results to be, before even trying it? Assuming that turns out to be accurate that'll be a big time saver with MIDI programming interface available. | |||||
| | #7 | |||||
By this I mean, that after you take an unfiltered measurement and press the button for REW to suggest filters, you still need to play around with the filters in REW by both modifying the ones suggested and also entering your own until the 'corrected' graph that it shows is to your liking. Once you then manually enter those filters and then subsequently do another response measurement to see how it looks now with the filters in place, it's amazing how close that predicted corrected response actually was compared to the actual response.. brucek | |||||
| | #8 | ||||
| Re: Will my new BFD DSP1124P definitely not work with MIDI? Yeah, I've been dialing in manually on the BFD for over 5 years now. I have the 1124's predecessor (1100, maybe???) It has the midi ports, but I've never tried them. Instead I just got used to the jog and shuttle method. Once you get used to the interface it goes quick, especially since REW tells you all the settings you need (like coarse frequency, fine frequency, gain, and bandwidth). Looking up the frequency and estimating the proper bandwidth was part of a ugly game of trial and error before REW. Now it's ultra simple. I won't get greedy and demand MIDI ![]() enjoy the new toy! | ||||
