| BFD | Electronic Equalization Devices Updating DSP1124 v 1.3 to 1.4 PicturesDiscuss Updating DSP1124 v 1.3 to 1.4 Pictures in the Equalization | Calibration forum; Updating DSP1124 v 1.3 to 1.4 Pictures Finally finished the job. Tricky, but it can be done. First picture shows the six screws that need to be ... |
Views: 765 - Replies: 13
| Finally finished the job. Tricky, but it can be done. First picture shows the six screws that need to be removed to get to the guts. You will need a #1 and #0 Phillips screwdriver. Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #2 | ||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures Picture 2 shows my initial conundrum...I had screwdrivers that couldn't cut it. The top set from Radio Shack did not allow me enough grip to remove the screws. The bottom set has better handles and I was just barely able to remove the screws. The middle one wasn't easy. Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #3 | ||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures Finally got it opened .Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #4 | ||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures Here is the offending EPROM. Nicely glued into place .Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #5 | ||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures Used an X-ACTO knife to carefully slice and peal the glue away. Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #6 | ||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures Used a screwdriver to pry the old EPROM out. Note how the pins became distorted. This was because of the ring glued down adjacent to the EPROM. Had very little room to work around it. Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #7 | ||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures Empty slot. The hard ring with the green and white wires had to be loosened to have room to fit the EPROM. Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #8 | ||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures Finally fitted the new EPROM. Made sure all of the little pins were in the holes. Had to bend the pins ever so slightly to get them to fit. Pressed in place. Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #9 | ||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures Had to loosen these two screws in order to get the cover to fit right. Plugged it in and it is working . Will have to do some checking to see if the MIDI is working .Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #10 | ||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures You are to be congratulated on the quality of your photography. ![]() But what have you done with all the components inside your 1124P? ![]() | ||||
| | #11 | |||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures Quote:
Good job Ron... anyone attempting this install will find this very useful. brucek | |||||
| | #12 | ||||
| Re: Updating DSP1124 v 1.3 to 1.4 Pictures Excellent... ![]() I was thinking the same thing... the BFD could be made as little as 4" deep. | ||||
| | #13 | ||||||
And yes – great photography! I know a lot of people here are really going to appreciate your taking the time and effort to show us how easy this upgrade is. Good job! ![]() Regards, Wayne | ||||||
| | #14 | ||||
| Best part...the Midi interface now works! ![]() Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
