BFD redlines too easy..
Discuss BFD redlines too easy.. in the Equalization | Calibration forum; BFD redlines too easy.. First of all I has a 2 tempest IB.... which I was pretty happy with in my 275 sq. foot ...
Views: 651 - Replies: 13
Old 03-17-07, 06:48 PM   #1
Alias: mike
Loc: Montreal,Quebec
User: #4787
Since: Dec 2006
  canaris is offline
First of all I has a 2 tempest IB.... which I was pretty happy with in my 275 sq. foot room,then I added another 2 tempest for a total of 4. I was running the 2 at 4 ohms at 750 per and now the 4 at 8 ohms at 500 a pair... the problem is the 4 are barely doing what the 2 were.. I tried diffrent settings on the BFD ... but that didin't help much...I find it redlines way too easy..even tough the amp has lotsa of headroom left.
The settings on my AVR for the sub are at 0 db..the attentuators on my Crest 2600 amp are at 2 pm.. I was thinking of running them in bridged mode 4 ohms at 2000 watts ..even tough in an IB they don't need as much wattage.
What do you guys think?
Old 03-17-07, 06:59 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: BFD redlines too easy..
Switch the input sensitivity to the higher +4dBu setting..............
Old 03-17-07, 07:15 PM   #3
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Could something be out of phase?
-- Otto
Old 03-17-07, 08:34 PM   #4
Alias: mike
User: #4787
Since: Dec 2006
  canaris is offline
brucek wrote: View Post
Hey that seemed to work... no more redline..I must have checked those 100 times I always thought they were in the 'in ' position" so I never touched them..
I changed both input and output..is that okay...?
Old 03-17-07, 08:51 PM   #5
Alias: brucek
User: #6
The two switches are for the two channels. One for left and one for right.
They alter the operating range from consumer to PRO level, so the input and output maximum level changes to +16dBu (~+4.89vRMS) from +2dBV (~+1.26vRMS).
Old 03-17-07, 10:25 PM   #6
Alias: mike
User: #4787
Since: Dec 2006
  canaris is offline
Brucek..I just read in the BFD manual..to keep the setting to -10 ... is there any loss by putting it to +4?
Old 03-17-07, 11:17 PM   #7
Alias: brucek
User: #6
Not if the BFD is clipping all the time.
Not if the input level takes advantage of that operating range. If you have an input level that is always clipping the BFD, then you need more room. Hopefully the maximum level with this setting takes advantage of all the bits available. If you're only turning on the first few LED's at maximum input level, then you are losing resolution. Even if that's so, you can't use a setting that clips all the time.
Old 03-17-07, 11:47 PM   #8
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
canaris wrote: View Post
Not sure what you’re asking about here, why the extra subs are not adding anything, or why the BFD is clipping.
What does “different settings” mean? Different filters? That isn’t going to help anything, especially if your amps have headroom to spare. The BFD compensates for response problems, not output problems...
If the two Tempests were performing satisfactorily, adding two more and doubling the power would have got you something like 6 dB more output. That would probably make them too loud, so you’d turn them down to compensate (maybe that’s why the four are “barely doing what the two were”). The main benefit then would be improved dynamics with demanding passages. And even then you’d only see an audible improvement if your 2-Tempest set-up was running out of steam at times.
But you didn’t double your power. You had 1500 watts total before, now you have 2000. That’s only a 25% increase in power. The rule of thumb with increasing amplifier power is that you have to double it to realize any audible benefit, or it’s not worth the trouble. That’s probably why you aren’t getting more performance than you were before.
Wayne A. Pflughaupt
Old 03-17-07, 11:49 PM   #9
Alias: Pete
User: #2485
Since: Sep 2006
  PeteD is offline
If running at +4 creates noise floor problems, put it back into -10 mode, turn your AVR sub out down to the minimum (-10??) and crank up your Crest 2600. Like you said, you still have plenty of output left at the amp. I would not go +4 unless you have to - it sounds like you have plenty of room left at the amp to make up the difference and keep your BFD happy.
Old 03-18-07, 12:34 AM   #10
Alias: mike
User: #4787
Since: Dec 2006
  canaris is offline
Thanks guys...I would think that 1000 watts would be enough for 4 tempests in an IB configuration ,after all they are rated at 180 watts each in an IB...I don't want to over exert them but at the same time I don't understand why the 2 sounded better that the 4 ... before I was running the 2 in parallel at 4 ohms per side..now I am running them 8 ohms a pair ...maybe the amp is not optimised for 8 ohms..I will try to run them bridged 4 ohms.. for 2000 watts..thats like doubling them ..just have to be careful in not blowing them.
I tried this filter settings... 20 +6
25 +6
32 +6
40 +4
50 +4
That seems to have given it a bit of punch..playing some "chemical brothers"
I wil try bridged mode tomorrow and let you guys know....
Old 03-18-07, 08:38 AM   #11
Alias: Pete
User: #2485
Since: Sep 2006
  PeteD is offline
Now I am confused. Are you clipping the input or the output on the BFD?
What did your initial plot look like?
It is not clear why you are using all boost, unless there are a bunch of other cut filters that you didn't share...
Old 03-18-07, 11:40 AM   #12
Alias: mike
User: #4787
Since: Dec 2006
  canaris is offline
I don't understand your question Pete about the input/output clipping.... If the BFD goes in the red ,isn't it the output?
I am boosting to try to get this thing pumping..so I am trying the boost to see if there is any difference...cause running it direct... seems to lack punch.
Old 03-18-07, 12:19 PM   #13
Alias: brucek
User: #6
The IN/OUT switch controls the filters and the VU meter indications.
Holding the IN/OUT switch causes the IN/OUT Green LED to flash.
Momentarily pressing the IN/OUT switch causes the IN/OUT Green LED to go on and off.
1. Green LED OFF - filters off, VU meter monitors output level.
2. Green LED ON - filters on, VU meter monitors output level.
3. Green LED FLASHING - filters off, VU meter monitors input level.
We try and optimize the input level as much as possible with the trim adjustment in the receiver for the subwoofer output to the BFD.
Gain filters will make the output higher, demanding a lower input to compensate to avoid clipping.
Old 03-18-07, 03:08 PM   #14
Alias: Wayne
Loc: Katy, Texas
User: #8
As I noted previously, Mike, nothing you do with the BFD is going to fix output problems you may be having downstream.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332
