| BFD | Electronic Equalization Devices Pre-BFD jitters (questions).....:)Discuss Pre-BFD jitters (questions).....:) in the Equalization | Calibration forum; Pre-BFD jitters (questions).....:) A couple of pre-BFD questions (OK, four):
1) After reading the BFD manual and the Guide here, am I correct ... |
Views: 875 - Replies: 24
| Pre-BFD jitters (questions).....:) A couple of pre-BFD questions (OK, four): 1) After reading the BFD manual and the Guide here, am I correct in that I set the input level coming from the AVR via the speaker trim settings, then calibrate the SPL via the sub's gain? 2) I am running dual subs (not co-located), so do I need to hook each up to a different channel on the BFD (ie. both L and R) or can I simply run out of one channel and use a splitter? Does it make any difference to REW that there are dual subs when it assigns the filters? Do I need to set the filters for each sub independently? 3) When determining the house curve and dialing in phase, can I use the sine wave tones and freqency sweeps generated by REW? I have read that a sub can be damaged by playing loud pure sine tones. How loud is too loud? I'm nervous about inadvertantly damaging my drivers by doing something wrong... 4) Since I am only interested in the PEQ functionality, is there something I need to do to disable the rest of the stuff (feedback filters, etc)? I'm sure I will have more as I get more into it... Thanx, everybody! Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. Last edited by Vader; 04-05-07 at 09:34 PM.. | ||||
| | #2 | ||||||||
| Re: Pre-BFD jitters (questions).....:) Quote:
We set the trim output for the subwoofer by monitoring the input level of the BFD using its LED's. Once that's set, it's best not to touch it. So, if you need more or less level from your sub after that point, then use the subwoofer own amplifier volume control. If you find that once that trim is set and you add any gain to your BFD filters, you may need to turn down the input level to the BFD a little. When the BFD filters are in place the LED's monitor the BFD's output level..... Quote:
A lot of people use program 5 to remind them its the slot for 5.1 equalization. Use any of the slots you want though, but once you turn the BFD on for the first time, go to that program slot and turn all the filters off.... brucek | ||||||||
| | #3 | ||||
| Re: Pre-BFD jitters (questions).....:) 1. Yes, set the input while the BFD is in Bypass mode using your sub pre-out adjustment in your AVR. Then level match the sub to your mains using your sub amp volume control. 2. I have three subs, two in each front corner and the Behemoth in the back of the room. The same filters are used for all three subs... it works beautifully. I did not have to use a separate set of filters for each sub. Actually I believe it would be impossible to try and use separate filters for each sub and then when combined have a respectable response. Try it and you will see what I mean. Simply measure all subs and then filter all of them with one set of filters. 3. Not really an issue with REW since it is a sweep. I ran somewhere around 60-70 sweeps from 2Hz to 200Hz when I was calibrating the CM-140... never an issue. 4. Not really. If you are going to use an 1124P then you could go through all the other presets and turn them to "OF" for off so that if you inadvertently changed to another preset it would not affect your response. However, the chances of that happening are pretty slim, and you'd most likely notice it. EDIT: Looks like brucek and were typing at the same time... he's obviously a little faster than me. While he suggest preset 5, you might also consider preset 10, which a lot of people use and will hold in memory if the power is lost for some reason. | ||||
| | #4 | ||||
| Re: Pre-BFD jitters (questions).....:) Bruce, What is the recommended volume for the sine wave tones and sweeps, so that I don't damage the drivers? Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | ||||
| | #5 | ||||||||
Don't worry about damaging your drivers unless you, at some point, turn the volume way up. Once your volume levels are set for the sweeps and such, they should also be OK for pure tones. If you're worried about it, just make a note of your current volume setting, turn it way down, and increase slowly. You'll be fine... Quote:
Go for it! -- Otto | ||||||||
| | #6 | ||||
| Re: Pre-BFD jitters (questions).....:) And some type faster than others... lol... we are all over it this morning... huh? | ||||
| | #7 | ||||
| Re: Pre-BFD jitters (questions).....:) That's why I love this place! Thanx, all! Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | ||||
| | #8 | ||||
| Re: Pre-BFD jitters (questions).....:) You guys must have had a head start! -- Otto | ||||
| | #9 | ||||
| Re: Pre-BFD jitters (questions).....:) I was using short hand, not sure what brucek was doing... I think he has a secretary typing for him... ![]() | ||||
| | #10 | ||||
| Re: Pre-BFD jitters (questions).....:) Hey Vader, I've just completed my first REW BFD setup and I couldn't be more happy with the results! My room was really ruining some of the HZ in my LFE--now the 4 filters I added have toasted the "one note" boom I was having. Neither my M&K sealed nor my ported SVS were able to get out of the trap! Enter REW and the BFD... brucek has been a champ at helping me through the steep learning curve (at least for a super-low tech like me). Looks like you're in good shape instructions-wise. Are you using a laptop or an HTPC? I'm anxious to see some graphs and hear your impressions! -- Phil Dali Mentor 8's/Mentor Vokal/Euphonia Phantom 5.1; Seaton Sound SubMersive ; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Nirvana!Planar 7060 until JVC gets lasers figured out... | ||||
| | #11 | |||||
| Re: Pre-BFD jitters (questions).....:) Phil, My computer is just an ordinary desktop PC in another room, to which I ran a couple of RCA audio cables (the longest Rat Shack had) in order to take measurements. I am looking forward to hearing what this thing (the BFD) can do for me, especially since I think the sound is pretty awesome right now! A few more questions (told ya... and I don't even have the BFD yet - this weekend, hopefully): Quote:
2) When entering the house curve data in REW, does it automatically adjust the filters for it, or is there something else I need to do? 3) Can anybody suggest a good bass-heavy sequence to set the input level? Given that there is a tremendous amount of variation between the sound level of different DVDs (ie. I cannot listen to Underworld at higher than -18dB, but Batman Begins weighs in at -10dB), does this mean that I need to reset the BFD input level for each film (That's crazy, I know...) 4) I leave my subs on auto-on. Will I get a loud "pop" when the BFD is turned on, or would you guys recommend that I leave the BFD on 24/7? Thanks! Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. Last edited by Vader; 04-05-07 at 09:34 PM.. | |||||
| | #12 | ||||||||
| Re: Pre-BFD jitters (questions).....:) Hi there... Quote:
-- Otto | ||||||||
| | #13 | ||||
| Re: Pre-BFD jitters (questions).....:) Ok, here are my preliminary results with the Galaxy 140 meter (no BFD yet): ![]() I determined the room curve by listening to a pure sine wave tone at 80 Hz (70 dB), then a second at 32 Hz, which I perceived to be at the same volume at 70dB (80Hz was 70dB, 32 was was bumped to nearly 83dB...?). When this curve was applied, most of my FR was below the target...?!? So, I adjusted the curve (cheating, I know) to the best fit against my FR, then listened again to both tones. Even then, I could see them as being the same volume. I do not claim to have golden ears, so it was pretty much a toss-up. The final curve is 80.0Hz=0.0dB; 32.0Hz=3.0dB. Does this sound in the ballpark for a 3200 ft^3 room? My next question is, do I really need a BFD (would the sonic differences be significant; I mean "boomy, muddy car sub vs. clean, tight home sub" kind of significant). I love the sound as is (if I don't know what's on the other side of the fence...), the FR does not have any huge peaks or nulls that I can see, and the improvement over my original placement (BIG null at 42 Hz) is huge. What do you guys think? EDIT: Now I'm confused. I was just playing around with the filters in REW, and it did not find all the peaks (to my eyes, the above FR has them at 20.9Hz, 25Hz, and a larger one at 46 Hz). REW only found the 20.9...?!? What am I missing? Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. Last edited by Vader; 04-07-07 at 08:30 AM.. | ||||
| | #14 | |||||||||
, but I'm not sure it's going to do you much good either. You want to fit your FR to your target, not the other way around. But that's OK for now. If you have enough headroom and amp power, I might suggest that you increase your sub output so that your measurements are mostly above the target (or simply lower the target in REW -- that's also in the "Target Settings" box as "Target Level"; just reduce that number and it will drop your entire target curve.). Then, when/if you apply filtering via BFD, you should be able to easily quash your peaks to hit the target level. Quote:
-- Otto | |||||||||
| | #15 | |||||
There's no problem with adding your own filters though, but be sure to press Optimise PK Gain & Q and Adjust PK Gains buttons to get REW to adjust them. You can force REW to consider more of your response by simply lowering the target level with its associated thumbwheel (as Otto pointed out already) after you've taken a measurement. Then do a find peaks again etc to see if it will come up with new filter suggestions. It's not too necessary in your case since you've really just got a small peak around 46Hz. Manually tweak it in REW and then enter the filter and remeasure. brucek | |||||
| | #16 | |||||
After playing around with last night's data in REW, applying three filters (one automatically found, two manually entered) and lowering the target level, here is the response I came up with (all filters were to lower peaks, not raise them): ![]() As a physicist (by training, anyway), I know that theoretical and real world results are rarely similar. How far away from these results am I likely to be (I have this mental image of Shrek saying "far, far away..." ) ?Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | |||||
| | #17 | |||||||
-- Otto | |||||||
| | #19 | ||||
| Re: Pre-BFD jitters (questions).....:) Well, I re-did my house curve completely by ear (as it is supposed to be - no cheating... ), re-ran the sweep, and played around with the filters. Here is my final graph (theoretical). I think I am gonna get the BFD just because this looks so pretty!![]() In the process of taking the room curve, I neglected to turn on the C-Weighting on the Galaxy meter, and as a consequence the 32Hz and 80Hz tones were actually much hotter than the 70dB (80Hz) and 82dB (32Hz) I read them to be (by about 20dB from what I can figure). Both were running for a minute or two as I took readings, but it does not appear to have done any damage to the drivers that I can hear (thankfully!). I re-did the curve properly, and came up with a House curve of about 12 dB between 32 and 80 Hz empirically. Thanks guys for all your advice and help! Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. Last edited by Vader; 04-07-07 at 09:24 PM.. | ||||
| | #20 | ||||
| Re: Pre-BFD jitters (questions).....:) Update: I almost pulled the trigger on a 1124DSP, but then ran across a thread at HTF where Sonnie mentioned the possibility of Behringer developing a PEQ specifically for HT applications. Given that I do not have any "peaks" to deal with, and my sound is quite good and balanced (relatively speaking), I'm gonna hold off for a bit. I am gonna re-tune my babies down to 16Hz tonight - I figure that after relocating them, I lost about 3dB off the AVR trim (so, for almost a year they were operating at 3dB above where they should have been, with no problem), and retuning to 16Hz only adds about 1.5-2dB to the calibration..... Besides, taking the tune down will naturally help the minor hump I have in the 20-28Hz band... Thanks, everybody! Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | ||||
| | #21 | ||||
| Re: Pre-BFD jitters (questions).....:) Heh, if you're waiting for a new product from Behringer, don't. You are correct in that your FR isn't that bad. But I wouldn't expect anything better than the BFD for some time (from Behringer or anyone else). And for the price tag (<$100), it can't be beat! -- Otto | ||||
| | #22 | ||||
| Re: Pre-BFD jitters (questions).....:) True. Hopeful thinking, I suppose (I have an inate talent for buying something, right before it's successor comes out)..... ![]() Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | ||||
| | #23 | ||||
| Re: Pre-BFD jitters (questions).....:) OK, I just got the BFD today, and I hooked everything up. Now the real questions begin... EDIT: Ya know.... I had several questions, each of which I answered my self with a little reading (again) of the manual and the BFD guide here on the shack. The only quetsion I have been unable to find an answer for is whether I need to worry about the 1.4 firmware upgrade. The date stamp on my unit is 0701, but I cannot find any version numbers. I do not intend on using the MIDI functionality, just the PEQ stuff (manually set)... That's all for now, but once I really get to playing this weekend, I'm sure I will have more. Thanks, all! Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. Last edited by Vader; 04-20-07 at 12:22 AM.. | ||||
| | #24 | |||||
brucek | |||||
| | #25 | ||||
| Re: Pre-BFD jitters (questions).....:) Thanks Bruce! It is already at 1.4 (Whew!). Guess I got one of the very last before they were discontinued! After playing some more with filter settings (the manual is less than crystal clear - to me, at least, I am starting to get a feel for this thing)... Peace... Vader Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors! One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them.... ![]() The Overlook Theater - Not liable for injuries sustained while laughing. | ||||
