No "response" from BFD
Discuss No "response" from BFD in the Equalization | Calibration forum; No "response" from BFD Hi all, I need help with my BFD. I reset my BFD; now the plots are the same shape no ...
Views: 672 - Replies: 9
Old 05-04-07, 02:19 PM   #1
Alias: Paul
Loc: Wichita, KS
User: #3420
Since: Oct 2006
  pgoko is offline
Hi all,
I need help with my BFD. I reset my BFD; now the plots are the same shape no matter what I put in the filters. The only change is the whole plot moving down when do a cut or moving back up when I do a boost. This is driving me nuts as I am longing to listen to my new IB with some equalization. Thanks in advance for the help.
Paul
Old 05-04-07, 02:25 PM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: No "response" from BFD
Hi Paul,
Are you saying that applying any filter in the BFD gives an across-the-board decrease in overall output? Can you post some before and after graphs, as well as the BFD filter settings for each?
-- Otto
Old 05-04-07, 02:31 PM   #3
Alias: Paul
Loc: Wichita, KS
User: #3420
Since: Oct 2006
  pgoko is offline
No Otto,
the new plot drops below the original retaining the same shape, kinda like a big arc atop a smaller arc.
I will try and see what I can do to post the graphs. Thanks for replying.
Old 05-04-07, 06:18 PM   #4
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Sounds like you’ve been bit by the “kHz” oversight, Paul! When you select the “Frequency,” make sure the little light to the right of the number says “Hz” and not “kHz.”
Old 01-07-08, 01:03 AM   #5
gbondioli
Inactive
Alias:
User: #
Posts: n/a
I used the SEARCH function to try to find an answer to my similar problem. I am uploading filters from REW to BFD via MIDI. But when I remeasure my response, it is exactly the same, no matter which filter set I use. Am I supposed to do something to activate a filter besides select it with the jog dial? For example, I have [In/Out] lit solid, [Engine L] and [Engine R] lit solid, and "4" selected on the jog dial. My graph is almost exactly the same no matter which filter I use!
Old 01-07-08, 06:43 AM   #6
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
  atledreier is offline
Mine says 'RUN' when it's filtering...
Old 01-07-08, 08:28 AM   #7
Alias: brucek
User: #6
  brucek is online now
You may have version V1.3 firmware in the BFD where the midi doesn't work. Read this thread.
Have you looked whether the filters are loaded by examining them using the front panel controls?
Old 01-07-08, 01:54 PM   #8
gbondioli
Inactive
Alias:
User: #
Posts: n/a
1.3 = sucks for me
So, do you think Behringer is still sending out free v1.4 eproms for units under warranty?
Also, has anybody seen my receipt laying around?
Old 01-07-08, 02:33 PM   #9
Alias: brucek
User: #6
I believe they are.............. I'll bet I can enter the filters into your BFD before you can even hook up a midi cable. Just enter the filters by hand and save time..
Old 01-07-08, 07:05 PM   #10
gbondioli
Inactive
Alias:
User: #
Posts: n/a
I have entered some values in by hand. It's not so bad. But now that I've got the basics of REW and the BFD, I would like to play around some more. MIDI would make that easier. I have one really super nasty dip at about 33Hz, down 25 decibels!!! I definitely need to experiment with sub placement.
