DEQ2496 opinions
Discuss DEQ2496 opinions in the Equalization | Calibration forum; DEQ2496 opinions While at the shop ordering an 1124P, the tech guy showed me this piece, an Ultra Curve Pro DEQ2496 http://www.behringer.com/DEQ2496/index.cfm?lang=ENG ...
Views: 1191 - Replies: 5
Old 05-05-07, 04:04 PM   #1
Alias: Edward
Loc: Brampton ON, Canada
User: #8188
Since: Apr 2007
  clubfoot is offline
DEQ2496 opinions
which he said would do everything the 1124P does and more, and I would not need computer software or purchase a mic pre ampand phantom power. I still ordered the 1124P, but am looking for opinions on the DEQ2496 as a total replacement to using REW, i.e. ease of use, flexibility, features,...would you purchase one?
Old 05-05-07, 04:08 PM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: DEQ2496 opinions
Hi clubfoot,
There was some relatively recent discussion on the DEQ2496 here.
-- Otto
Old 05-05-07, 05:00 PM   #3
Alias: Edward
User: #8188
Since: Apr 2007
  clubfoot is offline
Thanks, I just saw your thread. I want it more as a replacement for REW, 1124 and mic. It certainly has allot of features for the money.
Old 05-05-07, 05:18 PM   #4
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
  Otto is offline
Hi there,
I don't think it will be able to replace REW or the mic. I don't think their RTA will be as powerful, cool and subwoofer-specific as REW. Also, I don't think that the 2496 comes with a mic, but it may be able to help you avoid buying a preamp. It definitely does have more features than the 1124, and I'm still considering it.
-- Otto
Old 05-05-07, 08:09 PM   #5
Alias: terry
Loc: bathurst nsw australia
User: #1819
  terry j is offline
Of course it all depends on what you want to do with the 1124. If it is only to eq the bass, well in that case you don't need a mic and phantom power anyway, just a good old R/S meter.
No matter what you used the deq for, I would ALWAYS still use REW to fine tune everything. The results gotten via the automated functions on the unit are good, but can always be tweaked, and to do that you need rew and the mic that you would have used on the deq anyway, PLUS a means to use the mic for full range (if that is what you want) as the R/S meter is no good up high.
If you are only using it down low (as you would with the 1124) then you wouldn't use the inbuilt rta below 80 hz anyway, the manual even makes that clear, you save the money on the mic and use the R/S meter again and enter the results manually.
Hope that made sense, I'm still waking up!!
Old 05-06-07, 11:25 AM   #6
Alias: Edward
User: #8188
Since: Apr 2007
  clubfoot is offline
Thanks terry and otto, I have the 1124 on order and will pick up a mic and amp later on.
