Equalizers
Discuss Equalizers in the Equalization | Calibration forum; Equalizers If someone wanted to "depress" the frequency range across a broad spectrum, anyone have an inexpensive EQ you would use? ...
Views: 808 - Replies: 1
Old 05-14-07, 08:56 PM   #1
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
Equalizers
Here's the backround:
I'm currently in the process of building a mini line array -- 12 "full range" drivers and a horn tweeter per speaker.
  • The "Full Range" driver is flat to about 200hz.
  • With all of the drivers coupling, I have an SPL of ~102db at 80hz with only 8 drivers, much less the 12 I'll be using. Of course, it's much louder (~10dbs) at 200Hz.
  • I'm going to go with an active crossover with this system.
  • My initial crossover point is going to be relatively high.. maybe in the 6k-8k range
What I'm thinking about doing is reducing the output of the tweeter via its amp and "depressing" the frequency band from the crossover to ~60Hz to get a flat FR that will meld with the subwoofer I'm also building -- an ACI SV10" driver and plate amp I found on Craigslist for $80.
So, any suggestions? Again, inexpensive is the word here. I will actually probably use the BFD for the time being, but eventually "upgrade" should I like the results of my project.
JCD
Old 05-14-07, 09:36 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Equalizers
Not quite getting your set-up there, but if you want an inexpensive yet flexible EQ, look for a pair of older dbx or Symetix ½-rack space parametrics on e-Bay. I think a few other companies like Presonus still sell them new, but of course that will be more expensive.
Other options of decent-quality gear would include the older 3 or 4-band Ashly parametrics, although I expect they’ll cost a bit more. A rare stereo model is up on eBay right now – primo condition from an installation.
http://cgi.ebay.com/Ashly-PQ66-param...QQcmdZViewItem
(If you plan to display it in your equipment rack, this particular incarnation is more attractive than its predecessors. A subsequent PQ-16 (mono) and PQ-26 EQ (stereo) is even better-looking, if you can find one, but will probably be quite a bit more expensive. I think I e-Bay’d my PQ–16 for $165 several years ago.)
Of course, Behringer has an analog parametric you can probably find cheap – like the ½-rack models, you’ll need a pair of them. I’d put my money on the Ashly, though.
I think I’d avoid the analog Rane PE- parametrics. I’ve used the PE-15 in a PA systems, and it injected some audible high-frequency hash into the system.
