Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! RAM Electronics: Audio, Video, Home Theater and Computer Cables. PacParts: Replacement parts & accessories from the most recognized manufacturers in the Consumer Electronics Industry! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices Fi Audio: Infinitely amazing balanced high end musicality designed drivers! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! BOCS - Power Up Your Tivo! Elite Screens offers the finest in affordable projection screens. Musicians Friend: Your one stop shop for microphones, mic amps and Behringer products. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels!
Go Back   Home Theater Forum - Home Theater Systems - HomeTheaterShack.com > Equalization | Calibration > BFD | Electronic Equalization Devices
dcx 2496 software upgrade help  Discuss dcx 2496 software upgrade help in the Equalization | Calibration forum; dcx 2496 software upgrade help hi guys, this is your resident computer idiot asking for help. I want to upgrade the software on the dcx ...
Views: 1384 - Replies: 3
Old 06-26-07, 11:48 AM   #1
Alias: terry
Loc: bathurst nsw australia
User: #1819
  terry j is offline
I want to upgrade the software on the dcx 2496, the latest is v1.16a or whatever, mine out of the box is v1.14.
I think the latest upgrade has as part of the package the on-screen editor, which I have and use with the computer hooked up to the unit, so I'm halfway there. I have the rest downloaded (or so I thought) on the desktop, but get errors etc when I use the software update button.
Does someone have a link to a reasonably easy to understand procedure on upgrading the software??
Thanks for that, I know it must get irritating when an idiot has to have his hand held, but I must swallow my pride else I'll get nowhere!!
Old 06-26-07, 08:04 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: dcx 2496 software upgrade help
I don't have the 2496, so I can't help too much.
When you downloaded the zip file and extracted it, there would be the editor .exe and the .bin file (which is the firmware itself).
When you hit the update button (in the editor I suppose?), it should look and find the .bin file and ensure you have the connection to the DCX and start loading.
What does yours do exactly..?
Old 06-26-07, 09:17 PM   #3
Alias: terry
User: #1819
  terry j is offline
first off, here is the link if needed.
http://www.behringer.com/05_support/downloads.cfm?sel_prod=DCX2496&lang=eng
secondly, I have successfully downloaded and indeed use v 1.16a, the most current pc editor software, so I've done a little bit right.
The unit I was using did have the latest upgrade on it, but someones else did that a while back. That unit became faulty and I have a new one that I'd like to upgrade from v1.14 to v1.16 (15% extra computing power or whatever).
BRUCE, YOU"RE A GENIUS!
Not sure what I did differently, well yes I do. I had found the .bin thing before, but it always came up as VLC media player, with play, reverse, forward,stop etc etc, but nothing ever played! sp I always got rid of it hah hah.
When it worked this time I thought to myself "I'ze .bin looking for that!"
turned out easy in the end, got myself confused (see, computer idiot) but once again Bruce thanks, you're a gentleman and a scholar.
Old 06-26-07, 09:47 PM   #4
Alias: brucek
User: #6
  brucek is offline
Great.....
Funny guy.......
Bookmark and Share
Dish Network
