| BFD | Electronic Equalization Devices Auto Set-up/EQ AmpDiscuss Auto Set-up/EQ Amp in the Equalization | Calibration forum; Auto Set-up/EQ Amp Hi Guys,
I've just upgraded my amp to Yamaha's Z9, which i think is the first time i've had a ... |
Views: 1210 - Replies: 1
| Auto Set-up/EQ Amp Hi Guys, I've just upgraded my amp to Yamaha's Z9, which i think is the first time i've had a current flagship model (expect a new one next week ). Anyway this great beastie comes with a mic and an auto set-up and EQ routine. Should i defeat my BFD and let it auto eq and then measure and re-set-up the BFD, or do i leave it on and let it EQ over my set-up ( a slight house curve with a kick low down, flat sounded a little emancipated). Also what are peoples views on the eq'ing amps...and should i go in and edit the amps auto set-up as i guess i could go through REW and DIY it ? Ta, Lee | ||||
| | #2 | ||||
| Re: Auto Set-up/EQ Amp We've had members here test and post the frequency response results of an 'after EQ 'from a receiver system, and it isn't that great. Prevailing sentiment appears to be to use the auto EQ first and then do your own BFD EQ after. brucek | ||||
