| BFD | Electronic Equalization Devices bfd output voltageDiscuss bfd output voltage in the Equalization | Calibration forum; bfd output voltage I was wondering if someone can assist me in a question I have. I have just placed a Crown XTi-1000 ... |
Views: 750 - Replies: 13
| bfd output voltage I was wondering if someone can assist me in a question I have. I have just placed a Crown XTi-1000 in my system for the subwoofer. According to the manual it needs 1.4 volts for "full rated power". I do have a BFD DSP100 in line before the amplifier. I have found the below information concerning the input voltage on the BFD. My question is, can anyone tell me if the output voltage from the BFD is either a constant 1.26 or 4.9? I am using a Denon 3803 to run everything. I cannot find the output of the sub preout in the Denon manual. I am just trying to match what the Crown is looking for. Thanks. BFD: The -10dBv setting allows a maximum input level of +2dBV, which is ~1.26vRMS. The +4dBu setting allows a maximum input level of +16dBu, which is ~4.9vRMS. Crown manual: Sensitivity (volts RMS) for full rated power at 4 ohms==1.4v | ||||
| | #2 | |||||
| Re: bfd output voltage Quote:
The Denon will likely output a typical +2dBV. This wouldn't be enough to clip the input of the subs amp, but would be close enough to be a good match. Choose the -10dBV position in the BFD and you're good. brucek | |||||
| | #5 | ||||
| Re: bfd output voltage Yeh, why using the BFD when there is a built in EQ in the crown ? Jean-Pierre Imbeau ROTEL RSP-1098|RCD-1072|RDV-1060|RT-1080|RLC-1040|RB-1080x2|RMB-1075|RSP-976 PIONEER ELITE PRO-940HD|BDP-HD1|inno|YAMAHA NS-1000|NS-1000M|CA-1010|CT-1000|TC-1000| YP-1000|PEERLESS XXLS-12x4|HP MediaCenter (Vista Madia Center) + HP MediaSmart Server (Windows Home Server) with 4TB 2.0 TB|BEHRINGER DSP1124P|ECM8000|TOSHIBA HD-A2 My Peerless subs building thread | ||||
| | #6 | ||||
| Re: bfd output voltage I am no longer using the BFD with the Crown. It seems to me, even though I have not been able to measure the output from the sub out on Denon, that the Crown is getting enough input. I have not starting using the eq in the Crown at this time. I have just not had time to mess around it with yet. I hope to be able to soon though. The reason why I had been using the BFD to the Crown was an attempt to get a close to the 1.4v it needs to run a full output. | ||||
| | #7 | ||||
| Re: bfd output voltage When you get around to it let us know how it turns out! Right now I am considering the crown as an alternative to the BFD + EP2500/1500 (I don't really need that much power and Crown has an excellent rep). | ||||
| | #8 | ||||
| Re: bfd output voltage Eyekode, You can check out this link over the Crown forum where this is talk about EQ with the XTi. I hope this is allowed to be posted. You may need to create an account (free) over there to read it but it is a good place to start. You will need to download the System Architecture program to use the EQ but it is easy and pretty cool to mess round with. http://www.crownaudio.com/forums/ind...showtopic=1976 | ||||
| | #9 | ||||
| Re: bfd output voltage Wow, it seems to be a verry powerfull option !!! Jean-Pierre Imbeau ROTEL RSP-1098|RCD-1072|RDV-1060|RT-1080|RLC-1040|RB-1080x2|RMB-1075|RSP-976 PIONEER ELITE PRO-940HD|BDP-HD1|inno|YAMAHA NS-1000|NS-1000M|CA-1010|CT-1000|TC-1000| YP-1000|PEERLESS XXLS-12x4|HP MediaCenter (Vista Madia Center) + HP MediaSmart Server (Windows Home Server) with 4TB 2.0 TB|BEHRINGER DSP1124P|ECM8000|TOSHIBA HD-A2 My Peerless subs building thread | ||||
| | #10 | |||||
I was just hoping to hear from someone that has actually tried to do this with an HT sub. The Crown forum is mostly populated by pro-sound guys who could care less about < 20Hz. Actually I don't really care about flat response below 20Hz either, just want to protect my driver. Would have been slick to be able to do it with one box. | |||||
| | #11 | ||||
| Re: bfd output voltage Please excuse my ignorance but I am not really familiar with the term “low shelf filter” (even tough it is probably known to everyone else). If by that you mean is 20 Hz the lowest you can set any filter on, either lowering or raising the db, than I believe you a correct in that, that is the lowest the BFD can do also. | ||||
| | #12 | |||||
This could be useful for protecting a ported subwoofer if the frequency could be set low enough. I thought the Crown XTI series amps had these for low-pass/high-pass. But reading the manual I don't see it now... | |||||
| | #13 | |||||
| Re: bfd output voltage Here’s what a shelving filter “looks” like. IMO, they are not suitable for driver protection. Stick with a high pass filter. ![]() Quote:
Regards, Wayne | |||||
