BFD or DCX or DEQ ???
Discuss BFD or DCX or DEQ ??? in the Equalization | Calibration forum; BFD or DCX or DEQ ??? Ok... I got a great deal on 4ea Crown XLS202D amps and thus my plans for my HT system have ...
Views: 953 - Replies: 1
Old 08-08-07, 07:53 PM   #1
New Member
Alias: Mark
Loc: Atlanta
User: #10658
Since: Aug 2007
  markdonnaharris is offline
Ok...
I got a great deal on 4ea Crown XLS202D amps and thus my plans for my HT system have suddenly changed. I found Home Theater Shack and have become very interested in the REW/BFD abilities in liew of my previously planned Velodyne SMS-1 option for sub EQ.
Yes, a slippery slope. Now I am wondering about using a BFD or DCX2496 or DFQ2496 on the front & center chanels as well???
Now for the questions?
1) am I adding too much noise to the system by adding these extra components?
2) unballanced -> balanced inputs... do I need a DI800 between my Pre->BFD?
2b) is one needed between the Pre->Crown Amp?
Here is the system:
Harman AVR645 Pre/Processor
Crown XLS202D amps all channels
Crown K2 bridged for sub amp
JBL HTI8 (1pair per channel net 4ohm load) F-C-R
JBL HTI8C Ls, Rs, Lr, Rr
JBL S1S-EX sub
Yes, Yes, in a pat life I worked for Harman and could buy Harman/JBL/Crown products at a very nice discount.
Anyway, any help, direction, observations would be helpful.
Thanks
Mark
Old 08-08-07, 08:29 PM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: FBD or DCX or DFQ ???
markdonnaharris wrote: View Post
Hi mark, and welcome to the Shack!
Good choice in the BFD. I understand that the SMS-1 is also a great product, but I like the BFD for its super flexibility and price!
In my opinion, probably yes. Go with room treatments to address higher frequency issues.
The BFD accepts balanced or unbalanced. You'll be fine. You might find you'll need a level boost, but deal with that later. No big deal, and I've never needed a level boost with a few different preamps.
That I don't know. But if you go pre->BFD->Crown Amp, it should work just fine.
Good luck and have fun!
-- Otto
