| BFD | Electronic Equalization Devices New DSP1124P BFD today!Discuss New DSP1124P BFD today! in the Equalization | Calibration forum; New DSP1124P BFD today! Hello! I stopped by Guitar Center today and they had one new BFD in stock (build date 0701 with 1.4), ... |
Views: 1337 - Replies: 27
| New DSP1124P BFD today! Hello! I stopped by Guitar Center today and they had one new BFD in stock (build date 0701 with 1.4), so I bought it along with a M-Audio MIDIsport UNO. I have no idea if I can get it all working, but am reading all the threads, manuals and help files for the BFD and REW. I'll try not to bother all of you too much, but I have a feeling I may need some help, as it seems overwhelming at the moment. Tom | ||||
| | #2 | ||||
| Re: New DSP1124P BFD today! Yeah, it seems a bit much at first, but if you read those REW Help files, you'll get onto it once you load the program and start playing around..... brucek | ||||
| | #3 | |||||
| Re: New DSP1124P BFD today! Quote:
Thanks, Tom | |||||
| | #4 | ||||
| Re: New DSP1124P BFD today! Hi Finalrinse, and welcome to the Shack. Sounds like things are going well so far. I've never used a B&K SPL meter, but I know they make nice stuff. I'd still poke around for a cal file, or the meter's stated frequency response. It'd be best to know for sure, but you move forward either way. I'd probably just start taking some measurements at this point. Get yourself familiar with the REW tool and see what it can do. Of course, it won't hurt to have the BFD connected, so you can do that if you're all ready to go. After taking a few measurements, you'll almost certainly want to make some adjustments, so it would be convenient to already have it in the circuit. To make measurements and adjustments using REW, you will need to use the sweeps that are generated by REW. AVIA and VE discs won't be any help here. You can use those test discs later to set your levels -- REW doesn't have any Dolby/DTS stuff in it, so it can't assign signals to each individual channel in your system. Good luck! -- Otto | ||||
| | #5 | |||||
![]() Regards, Wayne | |||||
| | #6 | |||||
Tom | |||||
| | #7 | |||||
Yes, I think within a few hours I will try to take some measurements. I think I will hook up the BFD. It looks like the REW help file gives two scenarios. The first one show not using the A/V receiver and the second one does. I'm leaning towards the first one, I guess I'm not quite sure at this point how to completely turn off my other 7 speakers, short of disconnecting them. what do you think? Tom | |||||
| | #8 | |||||
You disconnect the other speakers by disconnecting the speaker wires at the receiver (while it's turned off of course). Then when you need them, hook them back up (with the receiver off, of course). You only need to disconnect the two mains because all testing is done in stereo only mode, so the other speakers will not be active and so we don't disconnect them. brucek | |||||
| | #9 | |||||
Thanks! | |||||
| | #10 | ||||
| Re: New DSP1124P BFD today! I measured my system last night for the first time, and also had the BFD hooked up. My system sounds so much smoother now! I can now run my subs volume higher with a couple of the peaks gone. My subs are only good to about 30Hz though, at least that how it looks to me. I have (2) Energy 8" sub's Teed together. I'm in a fairly good size great room that is open to most of the house, not ideal. In the future I would like to replace them with one better sub, maybe $800 range. Anyway, getting back to the BFD; I forgot to save the filters as a file so I could pull them back up, I noticed the feature to retreave from the BFD is greyed out. I thought, well no problem, I'll just cycle through them on the BFD and write them down. I don't think they are exactly the same though, the frequencies look like they might be rounded out, is this true? Is there a way to read out the same what REW was reading? I'm very pleased so far and thank all of you! Please advise if I should change my filters? | ||||
| | #11 | ||||
| Re: New DSP1124P BFD today! Looks like a good job. Yeah, you can easily read the filters from the BFD and write them down and they will match exactly what REW suggested. Go to REW and click the EQ filters icon and enter a random filter and see how REW defines them. The frequency in the Frequency thumbwheel interprets what's on the BFD front panels two windows of Freq + Fine. REW also shows the Freq + Fine in Green for those numbers. So, you can recreate the exact match from the front panel. Why are you using such a high target crossover in REW and not something like 80Hz? Hopefully this is a measure of your sub(s) only without the mains? brucek | ||||
| | #12 | |||||
Thanks! Tom Last edited by finalrinse; 09-12-07 at 11:07 PM.. | |||||
| | #13 | ||||||
![]() brucek | ||||||
| | #14 | |||||
Thanks, Tom | |||||
| | #15 | |||||
Thanks | |||||
| | #16 | ||||
| Re: New DSP1124P BFD today! It's the firware revision that you're looking for. You need a vers 1.4 to have the software that works with the midi of REW. If you have vers 1.3 and you want to use midi to enter filters rather than the front panel entry method, you would need to change the eprom inside. brucek | ||||
| | #18 | ||||
| Re: New DSP1124P BFD today! Sonnie - (and Bruce, etc), I haven't set up my 1124P yet, but I have installed it and am running with no eq aplied for now. Mine shows Version 1.0, will this present any REW interconnectivity problems? | ||||
| | #20 | ||||
| Re: New DSP1124P BFD today! Hi all. Just got my BFD and am waiting for my second sub to arrive. I have a question about the use of REW. Once I have an REW measurement, do I use the EQ window (as shown above) to flatten the response curve, and then enter those values into the BFD filter by filter?? In the graph above, the EQ window shows a number of selected settings - those are what you pound into the BFD? Sorry if this is a dumb question, but it was pretty cool to see that REW "knew" the 1124. Thanks | ||||
| | #21 | |||||||
brucek | |||||||
| | #22 | |||||
| | #23 | ||||
| Re: New DSP1124P BFD today! Hi Michael, everyone, You can determine the firmware revision by powering up the unit while holding down the "Filter Select" -- Otto | ||||
| | #25 | ||||
| Re: New DSP1124P BFD today! I picked up a DSP1124P from a local (Oakville, ON, CAN) dealer yesterday. They sold me their floor model and it is likely a few years old ... it has version 1.0 firmware. Got it hooked up and set Input Level OK but hit a snag trying to Save manually input filters to Preset 4 (I don't have midi cable). When I power up, both Engine L and Engine R are lit and 4 is displayed (Preset 4 is remembered as last one selected before power down). I press In/Out to get it lit and then press BOTH Engine R and Engine L together to get Engine L lit alone (1 sub is connected to output 1). At that point Save starts flashing. I then select filter 1, set mode "PA" and set filter Freq/Cut/BW ... all the while Save is still flashing (normal). Then I press Save. The display and Save flash for a few seconds (Engine L and In/Out go out) and then the display stops flashing and Engine L and In/Out are on again ... BUT Save is still flashing! I press Save again and same thing. The Save light will not stop flashing. It's as if the unit is incapable of saving the filter since the manual states Save light should go out after the filter is saved. Am I doing something wrong? Answer: Yes! I just tried pressing Save twice fast and it works! I was pressing Save once, then waiting until flashing stopped, then pressing it again. Last edited by huff; 10-14-07 at 11:05 PM.. Reason: solved! | ||||
