Old BFD design software still available???
Discuss Old BFD design software still available??? in the Equalization | Calibration forum; Old BFD design software still available??? I need a program to manipulate curves in so that I can creat different house curves for REW. The old ...
Views: 514 - Replies: 7
Old 10-19-07, 03:14 PM   #1
JasonB
Inactive
Alias:
User: #
Posts: n/a
I need a program to manipulate curves in so that I can creat different house curves for REW. The old BFD design software that is pictured in some of the house curve information on this site would be perfect but I can't seem to find a download for it.
Thanks,
Jason
Old 10-19-07, 03:19 PM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: Old BFD design software still available???
I'm not sure I understand. You can create house curves in a .txt file. They don't need to be perfectly rounded.
-- Otto
Old 10-19-07, 03:26 PM   #3
JasonB
Inactive
Alias:
User: #
Posts: n/a
That would be true for a simple house curve, but I want to create other curves as well, such as one that rolls off the low end below 30 hz for higher spl listening. I have a program that I can trace spl graphs and conver them to text with. So what I need is a spreadsheet that will allow me to draw curves centered around 0 db. The easiest way to draw curves would be with a parametric eq simulator such as the old BFD design software I mentioned. I could use REW but it will not let you set the target level low enough to get the curves near 0 db.
Thanks,
Jason
Old 10-19-07, 03:53 PM   #4
Alias: brucek
User: #6
  brucek is offline
Why can't you create the curves around a 75dB target and then when finished, use the Trace Offset feature to add -75dB and then click Add offset to data?
Old 10-19-07, 04:00 PM   #5
JasonB
Inactive
Alias:
User: #
Posts: n/a
brucek wrote: View Post
Bruce,
I am using a spreadsheet called SPL Trace and I don't see any "Trace Offset" feature in the menues. Are you using a different spreadsheet?
I tried cheating by fudging the aligment values by telling SPL Trace that the levels on the graph were much lower than they were but it threw the scale off and my curve was much sharper than intended.
Maybe I am going about this the wrong way. If you were to create a target reponse that wasn't just a simple house curve how would you go about doing it?
Thanks,
Jason
Old 10-19-07, 04:10 PM   #6
Alias: brucek
User: #6
  brucek is offline
I was referring to using REW...................... in response to your statement , I could use REW but it will not let you set the target level low enough to get the curves near 0 db.
Old 10-19-07, 09:38 PM   #7
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Not sure I’m getting what you’re after either, but...
...you can create any kind of house curve you want in REW. For instance, I use the following values in a .txt file to get a straight-line, hard-knee house curve...
30 0.0
32 -0.5
45 -3.9
60 -5.9
75 -6.6
90 -6.0
...which looks like this:
Name:  6 db hard knee house curve target.jpg
You could easily add values to the top to make response slope down after 30 Hz...
10 -36.6
16 -20.5
22 -9.3
28 -0.5
30 0.0
32 -0.5
45 -3.9
60 -5.9
75 -6.6
90 -6.0
...and REW would display them as a target that looks like this:
Name:  reverse house curve.jpg
Naturally, you can use whatever values you want to get the below-30 Hz slope you're after.
Old 10-19-07, 10:11 PM   #8
JasonB
Inactive
Alias:
User: #
Posts: n/a
Thanks all,
Bruce's reply gave me an idea and I can get REW to do what I want now. I started by creating a text file with flat response from 10 to 200 hz at 0 db. I then load it in to REW and apply filters to it until i get the curve I am looking for. Then I save that as a JPEG and use SPL Trace to convert it to a text file. I guess it would be simpler just to write house curves in Notepad but I find it easier to draw it first and then convert to text.
Jason
