BFD | Electronic Equalization DevicesDiscuss Ordering cables for the BFD in the Equalization | Calibration forum; Ordering cables for the BFD I emailed a well known cable supplier about getting some RCA to 1/4" cables to hook up the BFD and ... |
Views: 1009 - Replies: 7
| Ordering cables for the BFD I emailed a well known cable supplier about getting some RCA to 1/4" cables to hook up the BFD and I was asked the following: "We can sell you 1/4" to RCA cables. Are they TRS 1/4" or TS 1/4". If they are TRS 1/4" and are coming out of a balanced connection then you can order these cables as 1/4" to 1/4" in our balanced section and leave a note during checkout stating that you really want 1/4" to RCA cables. In addition, we'll need you to leave a note with the manufacturer's recommended pinout information. This is usually found in the manual for the balanced device - different manufacturers have different recommendations when going from a balanced device to an unbalanced device and we like to wire them according to those recommendations. If you need 1/4" TS to RCA, then we can build these for the price of an RCA to RCA subwoofer ........" With my electrical skills limited to turning lights on and off, I have no idea. Can anyone provide any feedback (no pun intended) on what is best here? Thanks. | ||||
| | #5 | ||||
| Re: Ordering cables for the BFD how come in the manual it says they are 1/4 TRS inputs and outputs??? also whichever cables they are where would i get some? could us just use one of these on an existing sub cable??? http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=091-1010 Last edited by frockc; 01-27-07 at 09:03 PM.. | ||||
| | #6 | |||||
| Re: Ordering cables for the BFD Quote:
brucek | |||||
| | #7 | |||||
![]() Here are some options, ranging from cheap to expensive. http://www.ramelectronics.net/html/RCA-to-1-4.html http://www.music123.com/Product/Product.aspx?SKU=128202 http://www.audio-discounters.com/pprc-j05.html http://store.a2zcable.com/audio-rca-to-1-4-inch-audio-cables.html Regards, Wayne | |||||
| | #8 | ||||
| Re: Ordering cables for the BFD Thanks Wayne. That last picture looks like a great way to go. Unfortunately my RCA run from the receiver is fished through a wall and under carpet and just not worth pulling up. So I am using just the standard radio shack 1/4" to RCA gold plated plug. Fortunately I do not have any hum, noise or signal loss that I can tell at least so hopefully this is "good enough". | ||||
