| BFD | Electronic Equalization Devices Will a USB Sound Card adapter work?Discuss Will a USB Sound Card adapter work? in the Equalization | Calibration forum; Will a USB Sound Card adapter work? Like this: http://cgi.ebay.com/USB-External-Sou...QQcmdZViewItem
Thanks... |
Views: 621 - Replies: 4
| Will a USB Sound Card adapter work? | ||||
| | #2 | ||||
| Re: Will a USB Sound Card adapter work? Assuming you’re wanting to use it for REW – nope. You need one with line in and line out connections. Regards, Wayne | ||||
| | #4 | ||||
| Re: Will a USB Sound Card adapter work? I don't know if you can still get them, I'm using a Creative USB Sound Blaster MP3+. It has the required inputs/outputs and works real well with REW. ![]() Good luck -john | ||||
| | #5 | ||||
| Re: Will a USB Sound Card adapter work? Thanks. I'll see if I can find one and that it works with Vista. Well I found some for 15 bucks plus shipping. It does list Windows versions it works with but not Vista. If you're using Vista please let me know as my 1124 will be here Thursday. Thanks Last edited by warnerwh; 11-07-07 at 01:38 AM.. | ||||
