BFD | Electronic Equalization DevicesCan BFD be used on recording studio monitors? Discuss Can BFD be used on recording studio monitors? in the Equalization | Calibration forum; Can BFD be used on recording studio monitors? Everything I have been reading refers to the BFD being used for subs and subs only? Can they be used ... |
Views: 669 - Replies: 19
| Can BFD be used on recording studio monitors? Everything I have been reading refers to the BFD being used for subs and subs only? Can they be used in a recording studio setup to achieve a flatter response at the mixing position? I hope so because I just ordered 2 of them and installed REW. I also wanted to add that I already have extensive broadband treatment in the room. It is a small room 10X12 and I am trying to obtain a super flat response along the quality to master in. Last edited by alw4416; 11-30-07 at 12:41 PM.. | ||||
| | #2 | |||||
| Re: Can BFD be used on recording studio monitors? Quote:
brucek | |||||
| | #3 | ||||
| Re: Can BFD be used on recording studio monitors? Oh no. Well I suppose I just wasted some money then..? So what is advisable, in addition to room treatment which I already have too much of in my opinion? What about IK Multimedia's new ARC system? | ||||
| | #4 | ||||
| Re: Can BFD be used on recording studio monitors? I have no experience with the ARC system, but it is targetted toward mixing and recording applications for a home studio, and is quite a bit more expensive. So, I suspect it would be better. The FBQ 2496 has better specs than the BFD 1124P. I would be much more inclined to test the FBQ out full range and see how you liked it. You simply wouldn't be pleased with the 1124P. brucek | ||||
| | #5 | ||||
| Re: Can BFD be used on recording studio monitors? The reason I ask about the ARC system is because I actually purchased it and I am not impressed at all. I have a pair of Dynaudio BM15A's and Adam P12 speakers and when I used the ARC system it completely killed the low end in my room. I noticed after experimenting that it does not like it when the speaker port holes are in the front as where they are with the BM15A's. I stuck a sock in the BM15A's port holes and re-ran the tests and the bass response got better. I simply can't rely on the ARC system. I will be surprised if the FBQ2496 wouldn't do a better job. I was using DBX EQ's 1/3 band octave to smooth out the response a little and they seemed to work fairly well, I am just trying to step that up. The frequency range I am targeting is only between 40-500hz. | ||||
| | #6 | ||||||
You can certainly give the BFD's a try, but I think you'll find the poor crosstalk (-76dB) and noise (94dB) not to your liking (especially nearfield). brucek | ||||||
| | #7 | ||||
| Re: Can BFD be used on recording studio monitors? I am an idiot when it comes to 'crosstalk' and 'noise' generated from the FBQ so can you put it in terms for an idiot? Do you think I am better off sticking with my DBX 31 band 1/3 band EQ? The reason I was looking to switch was because I can't dial in the specific frequencies I need to tame. Also what is your opinion on boosting a dip in the 70-80hz range? | ||||
| | #8 | |||||||
brucek | |||||||
| | #9 | ||||
| Re: Can BFD be used on recording studio monitors? So you are saying I should be fine with the FBQ but not the BFD? I believe the dip does respond as it does not appear to be an infinite null. How many decibel are you comfortable with when it comes to boosting? How many decibel when it comes to cutting? Also at what smoothing level in REW should I be working with the FBQ to smooth out my room response? Thanks for all the help by the way! | ||||
| | #10 | ||||||
Cut as much as you like, but of course, this lower the output level of the FBQ at that frequency. Sometimes you can cut so much and so wide that you're left with nothing... Quote:
brucek | ||||||
