BFD as a low pass
Discuss BFD as a low pass in the Equalization | Calibration forum; BFD as a low pass Hello there, I have a question concerning using a BFD as a low pass filter for my sonosub. I have ...
Views: 1244 - Replies: 27
Old 12-13-07, 01:36 PM   #1
Alias: sil180sr
User: #14248
Since: Dec 2007
  sil180sr is offline
BFD as a low pass
Hello there, I have a question concerning using a BFD as a low pass filter for my sonosub. I have a HK-3485 which gives a full signal subwoofer out and that gets passed to my ep2500 to power my sono sub. Is it possible to get a BFD and add a filter to use it as a low pass at 150hz without using a mic to test for SP? I did plan on eventually using the BFD for EQ just dont have the time to figure out how it works and was curious if I could use it as a low pass filter until I got the chance to properly set up the BFD to do EQ and low pass at the same time. Thanks!
Old 12-13-07, 02:13 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: BFD as a low pass
Yep, but it takes more than one filter depending on how perfect you want it and at what slope.
Why 150Hz? and not 80Hz..............
If you need help with the filters required, I can create them for you, but it's not too difficult to do yourself..
Old 12-13-07, 02:44 PM   #3
Alias: sil180sr
User: #14248
Since: Dec 2007
  sil180sr is offline
brucek wrote: View Post
I just used 150hz as a arbitrary figure, although im not sure if my mains produce that much bass to begin with. I did happen to read a similar thread where you responded with regards to using the bfd as a low pass, but was quite confused about .. pretty much everything you said . I did happen to read through the BFG guide but It really just blew by me. If you could maybe link me to previous threads which have maybe gone through a step by step process in going about the whole process that would be awesome. Thanks again!
Old 12-13-07, 03:15 PM   #4
Alias: brucek
User: #6
I don't know that we've ever discussed using the BFD as a low pass/crossover with enough detail that it would be useful for you.
Basically you need to first install the BFD between your receiver and subwoofer power amp and get that working with the BFD in bypass mode. Then simply enter the filters required to create the LPF (low pass filter). To enter filters into the BFD, use the BFD users manual obtained on-line from Behringer. It tells you how to master the front panel entry.
To create the filters required to setup a LPF in the BFD, download REW software into your PC and enter filters until the results you are looking for match the target you have set. As I said before, if you have trouble with this part, I can help you through it, or I can simply give you the filters to do the job............
Old 12-15-07, 08:18 PM   #5
Alias: sil180sr
User: #14248
Since: Dec 2007
  sil180sr is offline
Im considering purchasing the FBQ2496 instead of the DSP1124. Just want to make sure the FBQ will do the job just as well as the dsp. Ive probably read 5 threads comparing the two and they seem to be neck to neck. I will most likely just be entering everything manually (not using midi) and leaving it on one setting. Which is one reason why Im opting for the fbq. Just want to get a go from you guys before I press the order button!
Old 12-17-07, 02:17 PM   #6
Alias: brucek
User: #6
Yeah, I think the FBQ is a good one to get given your requirements.
Old 12-19-07, 08:53 PM   #7
Alias: sil180sr
User: #14248
Since: Dec 2007
  sil180sr is offline
sounds good, I put in a order for a fbq. In the mean time ive been reading the bfd and rew guides. I seem to understand the eq process but im still confused about the filters. Do I just select LP @ 80hz?
Old 12-19-07, 11:17 PM   #8
Alias: brucek
User: #6
I don't really understand the question. Can you rephrase it another way. Where are you talking about about selecting the LP?
Old 12-20-07, 12:15 AM   #9
Alias: sil180sr
User: #14248
Since: Dec 2007
  sil180sr is offline
Sure. Im referring to the EQ Filters Panel, I would check one of the 12 filters and Select the filter type as LP and frequency at 80 hz to select a 80 hz lowpass filter.
Old 12-20-07, 05:35 AM   #10
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
You have the wrong equaliser type selected, the BFD does not have LP filters. Select FBQ2496 in the Equaliser menu.
Old 12-20-07, 08:30 AM   #11
Alias: brucek
User: #6
Do I just select LP
Ahh OK, yeah, as John points out, you have to select FBQ, and then there will only be one type of filter.
Set a target in REW and enter filters until you see the filter line track that target. Be sure to deselect the check box of all the other lines on the screen except for FILTERS.
It's a bit of trial and error, but you'll see it's quite easy to do with not too many filters.
Old 12-25-07, 06:23 PM   #12
Alias: sil180sr
User: #14248
Since: Dec 2007
  sil180sr is offline
Happy Holidays! My order for the fbq ended up on backorder so I cancelled. Im thinking of ordering the 1124. Im curious if 12 filters is enough for setting EQ, lowpass filter @80hz and a highpass @ 10hz.
Old 12-25-07, 06:37 PM   #13
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
The BFD doesn't allow filters below 20Hz, and you can't even approximate an HP response with peaking filters. You might want to consider a DCX2496 which is aimed more at crossover applications and has a better set of filtering capabilities to suit.
Old 12-25-07, 09:52 PM   #14
Alias: sil180sr
User: #14248
Since: Dec 2007
  sil180sr is offline
Ive been reading a few threads regarding the DCX and DEQ models and it seems that im in over my head. I know that I want to be able to EQ, have a low pass@ 80hz and prevent my sub from bottoming out. Ive stumbled across a thread where brucek mentioned that a HPF at 10hz probably already exisists. Which has me thinking if a subsonic filter is really necessary, and if i really need to be spending more money on seemingly confusing gear.
As for the low pass filter, I read from another thread where brucek also mentioned that with roughly 6 filters on the BFD you can create a LPF that is mathematically the same as a LPF on crossover. Just thought I would share my thoughts to help clear any confusion I may be having. Thanks!
Old 12-26-07, 09:48 AM   #15
Alias: brucek
User: #6
Well, the EQ part is fine, and you can certainly make a decent resemblance to a low pass with the BFD, but the high pass isn't a function that can be created with filters that the BFD provides.
If you consider your sub audio chain (including the processor and BFD), it's entirely possible you may indeed have sufficient rolloff to protect your sub, but I wouldn't rely on it if you don't know for sure. You would have to test your own system with REW to find out. Ported subs will unload pretty quick, and so you want to check if you're OK before not using a subsonic filter.
Old 12-26-07, 05:47 PM   #16
Alias: sil180sr
User: #14248
Since: Dec 2007
  sil180sr is offline
maybe ill just get myself a 1124 and just start from there. Any chance I could get those filters created for 80hz?
Old 12-29-07, 09:19 AM   #17
Alias: brucek
User: #6
Yep, here's an 80Hz LPF that uses five filters. I guess it could be done in four, but I used an extra since I extended out quite far (which is probably a good idea).
Certainly in the area of interest the signal is down 45dB. That's certainly enough I would think.
I attached the REW .req file that you can load into REW and play around with yourself if you want, or you can simply read off the filters in the pic and enter them by hand.. I also attach a jpg of the area that your interested in so you can see how it tracks a standard 80Hz 24dB/octave target slope. Close enough.....
Anyway, you can also attempt to make your own when you become more familiar with REW. It's like a jig-saw puzzle to make one of these.
You can simply load these five filters into filter #8-12 of the BFD and forget them. Then you can use filters #1-7 to equalize. If you ever need more than seven filters to EQ a sub, you're doing something wrong...
80Hz filters
80Hz crossover.req
60Hz filters
Name:  60Hz crossover filters.jpg
60Hz crossover.req
Old 12-29-07, 05:53 PM   #18
Alias: sil180sr
User: #14248
Since: Dec 2007
  sil180sr is offline
awesome! thanks brucek!
Old 01-07-08, 05:32 PM   #19
Alias: sil180sr
User: #14248
Since: Dec 2007
  sil180sr is offline
Finally had a chance to punch in those filters and test it out, seems to work perfectly! Although I am a little puzzled when using REW. Im using the OSX version and when I load up the filters I get a strange looking graph, not to mention the values are different from the ones in the screen shot you posted. Maybe John can chime in on what im doing wrong? Thanks!
Old 01-07-08, 05:58 PM   #20
Alias: brucek
User: #6
Mmmm, don't know what happened there, sil180sr, but when I look at the req file that I attached in the post #17, it matches the wacky entries you have shown above. I have no idea how that happened.
I went to the file in my computer as I saved it and reattached it to the post again and deleted the old one.
"Save target" on the 80Hz crossover.req and load it into REW. It seems fine now. Go figure.
Anyway, the file (when it's correct) still looks somewhat like the one you show. For a sub we're interested mostly in the low end up to about 400Hz and then that's it. I did add filters up to 10K, but after that it really doesn't matter.
Name:  80 crossover.jpg
Old 10-26-08, 12:43 PM   #21
myn
Alias: myn
User: #2673
Since: Sep 2006
  myn is offline
Thanks for posting the 60hz crossover
Old 08-11-09, 07:22 PM   #22
New Member
Alias: Jake
Loc: Wellington
User: #22069
Since: Jun 2008
  jakenz is offline
Re: BFD as a low pass [with Marchand xm-46 High pass]
Hi,
First time poster - not sure of protocols re resurrecting old threads, but I have a question squarely related to the above discussion re using the BFD as a LP filter so hope this is OK.
My situation is that I have an SVS SB12 sub room equalised with a BFD 1124p and REW - per the great instructions on this site. The sub/mains crossover is currently set in my Yamaha receiver at 80hz, with the SB12's internal crossover disabled. This setup is working well. However I'm looking to change my setup to use a much higher quality stereo integrated amp (LFD Integrated zero LE) that I'd like to put back in service - but still make use of the BFD and the SB12 - putting aside any home theatre duties for the time being. From what I've read the optimal way to do this without compromising the higher frequencies fed to the mains but whilst easing the load on the wee LFD is to use a high quality line level crossover arrangement.
I appreciate I could just feed a line level stereo feed to the SB12 then use its internal crossover (variable LP & fixed 80hz HP) to feed the High passed > 80hz signal to the LFD to in turn feed the mains. That said I've read the SB12's LP filter is 12db/octave which I understand is not ideal if I set the crossover point as intended to 80hz and also that the quality of this crossover is probably OK but probably not realistically going to be as clear as a good external crossover. Also it'd mean long runs of line-level cable back from the sub to the amp. Instead I'm thinking of somehow using the Marchand XM46SB passive line-level high pass crossover - by all accounts I've read it's as transparent a crossover as you can get.
So, I was thinking of doing this - do you think it would work and any complications I should be aware of:
1. source/pre-amp line level stereo outs into 2 x Y RCA splitters (are splitters bad/ok?)
2. one side of each Y output feeds Marchand XM46 high pass filter set at 80hz (24db/octave)
3. Marchand feeds the > 80hz signal to LFD amp driving main speaker pair.
4. other side of each Y output feeds line level input to BFD... apply set of BFD low pass 80hz filters described by BruceK above
5. retain BFD previous room EQ settings in addition to new LP filters per 4
6. line level feed to SB12, with SB12 internal crossover disabled.
One slight variation of the above I've thought of would be to make use of the SB12's 12db/octave slope LP crossover at 80hz and supplement it with an 80hz 12db slope LP in the BFD... not sure if there's any benefit to doing this.
Note also: I'm aware there are a few volume level setting complications inherent in the above set-up... but for the mo am just focussing on getting the system-level crossover design clear in my head.
Sorry for the long first post but any feedback much appreciated!
Cheers,
Jake
Old 08-11-09, 08:14 PM   #23
Alias: brucek
User: #6
Why wouldn't you use the low and high pass of the marchand to do all the bass management?
Why 24dB on the high pass? Normally the high pass would be 2nd order and the low pass 4th order.
That's a no-no. The sub's own filter should be dialed out.
Old 08-11-09, 08:40 PM   #24
New Member
Alias: Jake
Loc: Wellington
User: #22069
Since: Jun 2008
  jakenz is offline
Wink Re: BFD as a low pass
Thanks for the quick response!
In a word - cost. Marchand's XM46 comes in several flavours - the standard XM46 is US$1000 which includes both the LP & HP you refer to - agree, with that one I'd just let it do all the work. They also do a cut down XM46SB which includes only a HP (or LP) filter for $250.
Given I already have the BFD I hoped I could make use of that for the LP filter, meaning the cheaper Marchand would suffice on the HP side.
Ah to be honest despite my throwing around a bit of HP/LP lingo around I'm very much a newbie to this... I'd assumed the LP rolloff rate (db/octave) should match the HP rolloff rate (db/octave) so give a flat frequency response around the crossover point... but from your response I take it this is not the case/a bit too simplistic?
Jake
Old 08-11-09, 10:24 PM   #25
Alias: brucek
User: #6
Makes sense.
Well, the standard (and I believe as per THX) is that the sub LPF is -24dB (4th order) and the mains are -12dB (2nd order). This allows the natural rolloff of the mains (that is in the order of -12dB) to be combined with the bass managements HPF to result in an overall -24dB...... so that hopefully both sub and mains are down -6dB at the 80Hz crossover....
