| BFD | Electronic Equalization Devices Test TonesDiscuss Test Tones in the Equalization | Calibration forum; Test Tones Hello: Are there any circumstances where the use of a signal generator would be preferable to a test CD?
Best ... |
Views: 589 - Replies: 10
| | #2 | ||||
| Re: Test Tones Yes, I personally think so. A (sinus) signal generator will give your the possibility to cover a large range of frequencies as you measure real-time SPL (with REW for instance) without changing tracks every time. In my opinion, this tool is very useful to find peaks and valleys very quickly: keep looking at your real-time SPL measurement while you cover the frequency range you're interested in. You can easily go back and forth, adjust the speaker placement, level and phase. One other problem with a test CD is that, by definition, it cannot reproduce all the frequencies and every track is time-limited. You don't have these problems with a signal generator. Hope this helps ! Note: REQ also includes a very complete signal generator and it's very easy to use Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha | ||||
| | #3 | |||||
| Re: Test Tones Quote:
Thanks Eric G. | |||||
| | #4 | |||||
That's how I have learnt how to do it: 1) Run a full sweep with REW. Stop here if you're happy with the results ![]() 2) Find the frequency that needs to be corrected 3) Generate this frequency and modify placement, phase, gain, etc in order to suppress the problem 4) Go to 1 Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha | |||||
| | #5 | |||||
Eric G. | |||||
| | #6 | ||||
| Re: Test Tones You're welcome ! I'm just happy to let you know how I got it from the guy who owns this one: Useless to say that he is very good at calibrating a system with many subwoofers. Yeah, I know it's crazy. He runs the system in 5.8 mode .... ![]() Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha | ||||
| | #8 | ||||
| Re: Test Tones Isn't that 'Flageborg's' setup? Sure looks like it. | ||||
| | #9 | ||||
| Re: Test Tones Yes, it is. But nobody knows who Flageborg is on this forum ![]() I had the chance to attend one subwoofer course where he helped a lot. Quite a guy ![]() Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha | ||||
| | #10 | ||||
| Re: Test Tones I'm not being critical, but I would think some room treatment would really make it sound a lot better. Bob "There is always hope, even if it is just a fool's hope." | ||||
| | #11 | |||||
