Help with BFD (newbie here)
Discuss Help with BFD (newbie here) in the Equalization | Calibration forum; Help with BFD (newbie here) Just finished building my sub. Here's the specs 1) 690 liters, Sonosub (pic attached..sitting beside my SVS PB12) 2) Ficaraudio ...
Views: 719 - Replies: 5
Old 12-16-07, 09:15 PM   #1
Alias: Matt
User: #8834
Since: May 2007
  Mattlock is offline
2) Ficaraudio Q18 single voice coil, 8 ohms
3) Powered by EP2500 running in bridged mono
4) BFD 1124 (but not setup yet)
The sub sounds awesome right now...but want to make it better
Attached is a graph of my curve without the BFD...
My settings were 1)EP2500 Gain - max 2) Sub setting on receiver -5.5 3) Volume set @ -20
I'd like to get some feedback on suggestions for setting my filters...What would be a good point for my line? (newbie here so I'm keeping it simple)
Keep in mind that my theater is used 100% for movies...
thanks
Matt
Old 12-17-07, 12:29 AM   #2
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Re: Help with BFD (newbie here)
Is that your sonosub only or does it include the SVS and mains also?
Old 12-17-07, 01:09 AM   #3
Alias: Matt
User: #8834
Since: May 2007
  Mattlock is offline
that is my sonosub (not PB12) and the mains....didnt know if the mains would be contributing under the crossover point...80hz
Old 12-17-07, 02:21 PM   #4
Alias: brucek
User: #6
  brucek is offline
Can you provide a response of the sub alone taken from the listening position (using the standard crossover you like to use)..
Old 12-17-07, 03:46 PM   #5
Alias: Matt
User: #8834
Since: May 2007
  Mattlock is offline
brucek wrote: View Post
will do Bruce...just bought a USB soundcard...will try my hand at REW soon
Old 12-17-07, 05:42 PM   #6
Alias: brucek
User: #6
  brucek is offline
Yeah, REW is really the way to go. The time spent learning how to use it will be worth it..
