FBQ2495 & REW couple of questions - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss FBQ2495 & REW couple of questions in the Subwoofer Equalization | Calibration forum; FBQ2495 & REW couple of questions Hi, Been using resonable settings for a few months but I fancy having a go at house curves and upgrading ...
Old 03-14-08, 05:17 AM   #1 (Link)
Alias: Bob
Loc: UK
User: #10457
Since: Jul 2007
mightyoakbob is offline
Hi,
Been using resonable settings for a few months but I fancy having a go at house curves and upgrading to REW 4.11. Some questions...
1) I've found I have to manually kill the existing filters on the FBQ2496 (from the front panel) before I can upload a new filter set from REW, otherwise according to the lights I get the old and the new filters added together. Is this right or am I missing something?
Is there an easy way to read the values of the filters I stored at the moment before i start messing so that I can put it back if I find no improvement?
Cheers,
Bob.
Old 03-14-08, 08:20 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: FBQ2495 & REW couple of questions
You can read the values from the front panel and write them down. Slow, but the only answer. The FBQ does not send info out the midi to the PC..
Old 03-14-08, 08:49 AM   #3 (Link)
Alias: Tim
Loc: North of Atlanta, GA
OvalNut's Avatar
User: #1625
OvalNut is offline
You can also exprt the filter values to a text file first before you load them to the FBQ, then retain that text file as your documentation of that filter set.
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
Old 03-19-08, 04:23 PM   #4 (Link)
Alias: Bob
Loc: UK
User: #10457
Since: Jul 2007
Thanks guys for your help but can I just clarify please.
Is it essential to clear old filters using the fbq2496 front panel buttons before I can load a replacement set of filters?
I have found that I did save (using REW save filters) the filter I am currently using. Can I create a new filter (to try house curves) load that into a clean FBQ left channel and then upload the old set into the right channel from the saved data I already have? Then I only need to swap the channel used on the fbq (swap the plugs) to try one filter against the other. Or is that rubbish?
Cheers,
Bob.
Old 03-20-08, 07:33 AM   #5 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
What you want to do with the left and right channels would work fine.
On your original question, there should be no need to clear old filters, REW clears all the filters before it downloads new settings. If that is not happening there may be something going wrong with the Midi transfer, so you would need to check carefully that the settings that end up in the unit are what you expected.
Old 03-24-08, 12:48 PM   #6 (Link)
Alias: Bob
Loc: UK
User: #10457
Since: Jul 2007
Thanks guys.
Cheers,
Bob
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
A couple of BFD questions... P-P-S-S BFD Forum 5 12-20-07 06:32 PM
About to take the REW/BFD plunge…A couple questions please alanb REW Forum 7 06-01-07 03:08 PM
getting ready for REW couple questions. adamanteus REW Forum 9 05-19-07 10:12 AM
A couple of basic questions for the Soundblaster live! 24 bit external abergdc REW Forum 4 03-12-07 12:18 PM
A Couple Dumb Measurement Questions mikie REW Forum 2 01-18-07 03:10 PM
Mach 5 Audio
