About on level keyboard key -10db/+4db - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss About on level keyboard key -10db/+4db in the Subwoofer Equalization | Calibration forum; About on level keyboard key -10db/+4db Hi, I am beginning here in the Home Theater Shack, and for what I read until the moment I liked ...
Old 07-21-06, 03:43 PM   #1 (Link)
New Member
Alias: Cocuroci
Loc: Recife - Brazil
Ronaldo Cocuroci's Avatar
User: #1552
Ronaldo Cocuroci is offline
Hi, I am beginning here in the Home Theater Shack, and for what I read until the moment I liked this space very, I wait to very learn and if possible to collaborate in what it will be possible.
I have a doubt with regard to the use of the keyboard keys of level of operation of BFD 1124, the fact of if using in -10db or +4db intervene only with the level measurer (leds of the panel) or influence in the internal processing of the signal?
Which the best form to use?
Old 07-21-06, 04:01 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: About on level keyboard key -10db/+4db
For retail equipment we normally use the -10dBv setting and for Pro equipment we use the 4dBu setting.
Can you explain your question further and maybe we can help....
Old 07-21-06, 04:07 PM   #3 (Link)
New Member
Alias: Cocuroci
User: #1552
Brucek,
The question is if this adjustment (- 10/+4) intervenes with the signal or it only modifies the scale of the display of level in the panel frontal.
Old 07-21-06, 06:13 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
I believe it intervenes to adapt the BFD electronics to the input level.
A PRO level can have a maximum ~+16dBu (about +5volts), where a consumer level will have a maximum of ~+2dBV (about 1.25volts). The switch ensures the electronics is padded accordingly.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
