No output to sub with 1124 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss No output to sub with 1124 in the Subwoofer Equalization | Calibration forum; No output to sub with 1124 I am hooking up my 1124 for the first time. I have set the input level but I am getting ...
Old 04-15-08, 03:22 PM   #1 (Link)
New Member
Alias: edge900rr
Loc: Columbus, Ohio
User: #18574
Since: Mar 2008
edge900rr is offline
I am hooking up my 1124 for the first time. I have set the input level but I am getting no output to the sub. the sub is just dead, with the BFD out of bypass mode it looks like it is sending a signal to the sub(output levels are moving) but there is no sound coming from the sub. any thoughts?
Old 04-15-08, 04:48 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: No output to sub with 1124
Is it sending a signal when in bypass?
Are the connections balanced or unbalanced?
Old 04-15-08, 07:43 PM   #3 (Link)
New Member
Alias: edge900rr
Loc: Columbus, Ohio
User: #18574
Since: Mar 2008
no there is no signal when it is in bypass (the in/out light flashing). I am using 1/4 mic jacks.
Old 04-15-08, 08:31 PM   #4 (Link)
Alias: brucek
User: #6
Can you be more specific. Are you feeding unbalanced to the BFD input with an RCA to 1/4" TS cable, and the same on the output of the BFD?
Old 04-15-08, 09:21 PM   #5 (Link)
New Member
Alias: edge900rr
Loc: Columbus, Ohio
User: #18574
Since: Mar 2008
yes. I just put it on "of" mode and the sub started working. I was under the impression that it needed to be in "pa" for the eq to be on.
Old 04-15-08, 09:30 PM   #6 (Link)
Alias: brucek
User: #6
OF turns of a specific filter and PA turns on the filter in parametric mode.
All filters should initially be placed in the OF mode for the program you want to use (i.e. Program 4) . This ensures that none are in the feedback destroy mode.
Old 04-16-08, 10:36 AM   #7 (Link)
New Member
Alias: edge900rr
Loc: Columbus, Ohio
User: #18574
Since: Mar 2008
so after I load the filters then I put it back in PA mode?
Old 04-16-08, 12:11 PM   #8 (Link)
Alias: brucek
User: #6
Yes, for every filter you use. Leave the rest in OF.
Old 04-17-08, 03:27 PM   #9 (Link)
New Member
Alias: edge900rr
Loc: Columbus, Ohio
User: #18574
Since: Mar 2008
sweet. thanks for the help
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
dsp 1124 evan Classifieds - Equalization and Calibration Equipment 3 11-20-07 01:09 AM
Sub output volume limitations and the 1124 duxfan BFD Forum 2 10-19-07 02:35 PM
Box Sub Output vs. IB Sub Output NickTF DIY Subwoofers - Infinite Baffle 15 10-18-07 09:25 PM
How do you get the info from RoomEQ to the 1124 doreytp REW Forum 5 07-22-07 08:53 PM
2496 vs. 1124 pwest BFD Forum 7 02-15-07 02:40 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
