Recalibrating BFD for new HT room - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Recalibrating BFD for new HT room in the Subwoofer Equalization | Calibration forum; Recalibrating BFD for new HT room We moved into a new house a few months ago and I am just finishing up with a dedicated HT ...
Old 07-25-06, 12:56 PM   #1 (Link)
Alias: Travis
Loc: I ain't tellin ya!
User: #1166
Since: Jun 2006
bass_addict is offline
We moved into a new house a few months ago and I am just finishing up with a dedicated HT room that has taken longer than expected. I am getting ready to redo my BFD and would like some input on a graph. The RAW is actual where the corrected is what I am thinking I want the line to look like. I just don't know how steep of a curve to make. I am just going to build the curve right into the setup instead of making a house filter separately. My only concern when calibrating with DVE is that the sub frequency is centered around 60 hz. If I eq the sub as follows will it be boosting the low end too much?
Room is 11x22 (I know, not the best dimensions but that's what I had to work with).
Sub is a Pb12+2, tuned to 16hz.
Thanks for the input.
Old 07-25-06, 01:27 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Recalibrating BFD for new HT room
I'm afraid I don't really understand what you're asking, but I'll comment on your graph.
I'm guessing the magenta line is your hopeful target? and the blue line is your raw measurement using tones?
You might consider using Room EQ Wizard if you want more accuracy.
I would consider taking your measurements at a slightly higher (~80-85dB) level.
If the magenta is your target, you may be ramping up too much at the lower end. Generally a slow rise from the crossover down to about 30Hz and then flat down from there is acceptable.
I wouldn't stop taking measurements at 100hz. Carry on to the end of the graph.
Old 07-25-06, 02:23 PM   #3 (Link)
Alias: Travis
User: #1166
Since: Jun 2006
Thanks,
Yes, blue is actual and purple is what I am trying to accomplish. I was more or less concerned about how steep a curve to make.
This is the graph in my old house.
There was a nasty hole at 63 hz that I couldn't get rid of.
How about this graph for the new one.
Old 07-25-06, 02:46 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Well, when you do your new raw measurement, you should measure at a higher level (~80-85dB). You're not outputiing enough level to do a proper measurement.
Again, you should rise from your crossover and then level off at about 30Hz and then go flat from there down.
Old 07-25-06, 03:23 PM   #5 (Link)
Alias: Travis
User: #1166
Since: Jun 2006
I do agree that I need to be at a higher level. The original one was done at 85 db's. This one will be reworked higher. I was just looking for some preliminary info more than anthing. I appreciate the input. When it is redone I will post a follow up for you to look at.
Travis
Old 11-16-06, 01:03 PM   #6 (Link)
New Member
Alias: Andrew
Loc: Sheffield UK
User: #4155
Since: Nov 2006
Andrew W is offline
I agree with Travis, take some readings further up, to around 200Hz or so, I have a theory that I will expand upon once I can see what is happening in that region.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
