New BFD... will you buy one? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss New BFD... will you buy one? in the Subwoofer Equalization | Calibration forum; New BFD... will you buy one? If Behringer were to produce a new BFD unit with the features below would you buy one? We need everyone's ...
View Poll Results: New BFD... will you buy one?
I prefer Unit A. 48 28.92%
I prefer Unit B. 62 37.35%
I would probably buy either unit they built, A or B. 49 29.52%
I would buy both. 7 4.22%
Voters: 166. You may not vote on this poll
Old 10-26-06, 02:59 PM   #1 (Link)
Loc: Lower Alabama
Sonnie is offline
Arrow New BFD... will you buy one?
We need everyone's participation, please vote!
Features Unit A (Retail $200-$250 / Street Price $150-$200):
~ Two independent channels.
~ A minimum of twelve parametric filters per channel (20 per channel is good too).
~ Channel coupling and series looping.
~ Three-way IN/OUT bypass.
~ Input/output LED level indicators.
~ LED filter indicators for both channels.
~ Front panel display.
~ Retain normal required buttons and jog dial.
~ 24-bit/96 kHz A/D and D/A converter powered by a 32-bit DSP.
~ Internal switch-mode power supply (100 - 240 V~ / 50-60hz).
~ Low power consumption.
~ Adjustable input level (-10dBV / +4dBu) on rear.
~ Hard bypass relay.
~ Noise-free.
~ 107db dynamic range.
~ 0.007% THD.
~ High-quality components.
~ High-quality construction.
~ Balanced XLR inputs/outputs.
~ Soft power ON/OFF with selectable Auto-On detect via sub signal.
~ Eliminate turn-on thump and ground hum.
~ Double insulated chassis with a two prong plug or a ground lift switch if needed to eliminate hum.
~ Pure flat frequency response from 10hz to 20khz* (FBQ2496 is -3db @ 20hz).
~ Filter adjustment capabilities from 10hz to 20khz*.
~ Adjustable gain range from -24db to +16db for each filter.
~ Minimum of 4 to 6 memory presets.
~ Replace ¼ inch inputs/outputs with RCA inputs/outputs.
~ Simple shelf filter… (i.e. selectable linear boost between two selectable frequencies).
~ Selectable and/or variable 6db-48db/octave subsonic roll-off filter from 35hz to 10hz (minimum 5hz increments).
~ Time delay from 0 to 30msec or 1 foot increments w/ 0.1 foot fine up to 30 feet.
~ Variable phase correction/adjustment from 0-180.
~ Front panel USB and/or RS-232 interface for MIDI port (place under small flip cover like on computers).
~ Dimmable front panel LED's / lights with OFF option.
~ Soft blue and/or green LED's on front panel vs. red.
~ Offer unit in black or silver… if not optional, offer only in black.
~ Revamp chassis for home theater consumer appearance vs. pro-audio style.
~ Allow mounting brackets to be optional (include unattached).
~ Enclose/fill gaps on sides if mounting brackets are removed.
~ Add rubber feet to allow placement on top of other equipment.
~ Remove graphic design from top of unit.
~ One year warranty.
Optional features in Unit A (If can be added at no additional cost):
~ Anti-clipping mechanism with higher dynamic peak input before clipping.
~ Frequency readout in hertz instead of base + fine… (1hz increments w/ 0.1hz fine increments).
~ Bandwidth readout in octaves (1/3,1/6,1/24,1/1, etc.) or hertz (2hz,5hz,12hz,etc.) instead of 1/60, 10/60, 60/60, etc.
~ Front panel volume/gain to control output level to sub.
~ Ability to slave multiple units together.
~ Linkwitz transform circuit.
~ Detachable power cord.
Added features of Unit B (Retail $250-$300 / Street Price $200-250):
~ Individual crossover filters (Butterworth, Bessel, Linkwitz-Riley) per channel w/ selectable roll-off 6db-48db/octave.
~ Adjustable/variable crossover range (low pass and high pass from 20hz to 200hz and w/ bypass).
~ Built-in RTA mic/line input w/ phantom power and w/ GAIN control.
~ Built-in SPL meter with selectable dBA/dBC/OFF weighting.
~ Built-in test tones (sinewaves - individual 1hz increments and sweep from 5hz to 400hz or 5hz to 20khz).
~ Separate RCA mic monitoring and test tone output to allow for computer program monitoring.
~ Locate RTA mic/line inputs and RCA monitoring outputs on the front face plate under a small flip cover.
~ Video output for monitoring the display would be nice, but the cost factor may prohibit this.
~ Video display instead of LED's… (dimmable and selectable OFF).
~ Small and simple 6 button wireless IR remote with discrete ON/OFF buttons and Preset 1,2,3,4 buttons.
~ Rear IR jack for remote control… to use with repeaters.
~ Add volume/gain control button to remote if feature is made available.
~ Add other control buttons to remote if cost feasible.
Old 10-26-06, 07:42 PM   #2 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Re: Poll: New BFD... will you buy one?
Yes.
Old 10-26-06, 09:30 PM   #3 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Sonnie wrote: View Post
Probably would want to leave it with the 1/4inch phono jack inputs, it's not too hard to convert to rca inputs and it would suit live sound applications a bit better to have native 6.5mm jacks on there.
Old 10-26-06, 10:46 PM   #4 (Link)
Alias: Ben
Loc: Manitoba
User: #739
Bent is offline
Yup - I'd buy another one if it had these specs.
Old 10-26-06, 11:24 PM   #5 (Link)
Alias: JP
Loc: Walla Walla, WA
User: #1573
JimPeitersen is offline
I would buy either unit, but would prefer "B" because of the added features. I already have a BFD, but a new model would be nice.
JP
Old 10-26-06, 11:34 PM   #6 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
I'd prefer B, if only for the remote control.
-- Otto
Old 10-27-06, 12:30 AM   #7 (Link)
Alias: Trevor
Loc: Regina SK.
User: #2597
Since: Sep 2006
titch-- is offline
I voted for B to.
Old 10-27-06, 09:33 AM   #8 (Link)
Loc: Lower Alabama
Sonnie is offline
Yeah that remote would be nice indeed... maybe somehow we can get that on Unit A as well.
Old 10-27-06, 10:12 AM   #9 (Link)
Alias: Robert
Loc: Dallas, Texas
User: #29
Robert_Gibran is offline
Ahem, where's the option for NADA? Velodyne SMS-1 and forgetaboutit!
RG
Old 10-27-06, 10:24 AM   #10 (Link)
Loc: Lower Alabama
Sonnie is offline
We really don't care how many don't want it... we only ask what we want to know...
Old 10-27-06, 12:15 PM   #11 (Link)
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
I voted for A because B is getting a bit complex and expensive, although there are features on it that would be nice.
The biggest things for me would be the shelf filter ability, the 2 pronged outlet/hum control, rumble filter, and the variable phase would be an awesome addition.
Old 10-27-06, 03:32 PM   #12 (Link)
Alias: Jim
Loc: Phoenix, Az
azjimmy's Avatar
User: #940
Since: Jun 2006
azjimmy is offline
I'd like to see either, but B looks like the one I'd go for, despite having a mixer, mic, SPL meter etc. I like the remote and the ability to have all the stuff I mentioned above in one unit.
Sonnie, does this mean we are coming up on a finalized product?
Jim
"Relax. Don't worry. Have a Homebrew."
Charlie Papazian
Old 10-27-06, 04:10 PM   #13 (Link)
Loc: Lower Alabama
Sonnie is offline
azjimmy wrote: View Post
No, I'm still trying to get Behringer to listen to us. I will simply continue to gather ammunition and they will have to sue me to get me to stop asking them to produce it. I'll go as far as I can for us all... You guys may have to bail me out of jail...
Old 10-27-06, 04:33 PM   #14 (Link)
Alias: O_ROD
Loc: Ontario, Canada
User: #3198
Since: Oct 2006
O_ROD is offline
I just purchased my first 1124, I don't really see any upgrades in the newer ones that'd warrant it's purchase. But, B for the remote and flexibility!
Old 10-28-06, 11:12 AM   #15 (Link)
Alias: LightwaveDude
Loc: North Central Iowa
User: #1822
LightwaveDude is offline
I prefer unit B, but I'd probably have to go with Unit A due to price concerns (teenage highschool budget).
Old 10-29-06, 08:50 PM   #16 (Link)
Alias: Hank
Loc: Austin, Texas
User: #3263
Since: Oct 2006
Hank is offline
Probably B, BUT I question that an SPL meter would be accurate enough and have the resolution I'd want for the addtional $50 or so.
Old 10-31-06, 08:09 AM   #17 (Link)
Alias: toecheese
Loc: Raleigh,NC
User: #356
toecheese is offline
Where's the voting option of 'I'll stick with my current BFD'?
Old 10-31-06, 10:33 AM   #18 (Link)
Loc: Lower Alabama
Sonnie is offline
We are only interested in those who are looking for a new one. You can keep yours...
Old 10-31-06, 10:56 AM   #19 (Link)
Alias: Aaron
Loc: Albuquerque, NM
JorgenMan's Avatar
User: #2040
Since: Aug 2006
JorgenMan is offline
I'm not sure any of the extra features in B would be worth it. I might say differently if I had them, but I think the features in A are good enough for what the BFD is used for, and for the extra cost, I'd prefer to have the phantom power, SPL meter, etc. in separate components.
My meager HT
It's like, how much more black could this be? And the answer is none. None more black.
Old 10-31-06, 11:04 AM   #20 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
For me, the optional (i.e., more than just LR) croosover types in B make it my choice.
JCD
Old 11-11-06, 03:03 PM   #21 (Link)
Alias: Huck
User: #2720
Since: Sep 2006
Huck is offline
Hi: On my BFD Pro I am using both engines , one for two-channel and the other for movies only, on two different set-ups, that is two different sets of speakers and two different sources( c.d. and dvd player).
I am getting a lot of cross-talk between engine L and engine R. I hope the newer model can address this! Thanks, Huck
Old 01-06-07, 07:23 AM   #22 (Link)
Alias: Bryan
Loc: Edwardsville, Illinois
muse77's Avatar
User: #4838
Since: Dec 2006
muse77 is offline
Re: New BFD... will you buy one?
I would buy B. I have an old BSR EQ-3000 that even a monkey can use . I desperately need an upgrade.
Bryan
Old 01-11-07, 09:23 AM   #23 (Link)
Alias: josh
User: #473
josh is offline
