Does calibration really make a difference? - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Does calibration really make a difference? in the Subwoofer Equalization | Calibration forum; Does calibration really make a difference? Progress. I got the REW signal generator working, and sending a signal to the sub. Doing a quick sweep, looks ...
Old 06-10-08, 02:10 AM   #26 (Link)
Alias: David
Loc: Los Angeles, Ca
User: #20731
Since: May 2008
htguy is offline
Re: Does calibration really make a difference?
Progress. I got the REW signal generator working, and sending a signal to the sub. Doing a quick sweep, looks like I have a peak some place between 55 and 65. I will do the time consuming test later. My wife thought the test tones were annoying. After I showed her the REW program and the meter, she at least now thinks this is mildly interesting.
Old 06-11-08, 02:09 AM   #27 (Link)
Alias: David
User: #20731
Since: May 2008
htguy is offline
Here is the result of my first graph. I used a RS analog meter, and I downloaded the excel spreadsheet. The signals were from the REW generator, Sine Wave. No dither added to output. RMS level dB FS at the default -20.0. My sub is crossed at 80, so I stopped testing above 100. I started at 10. Looks like I could use some EQ, but does this graph look "right?" Are the RS correction factors in the excel spreadsheet the most current ones? Thanks in advance.
Old 06-11-08, 12:22 PM   #28 (Link)
Alias: brucek
User: #6
brucek is online now
Yes, they match the downloadable .cal files (as long as you chose the one for your meter).
If you have a sub that you know will not reach down to 10Hz (given its specifications) then I would recommend not measuring that low. The problem is that noise can be interpreted as signal at those very, very low frequencies and with the compensation at 10hz which can be ~30dB with the old RS meter, it results in false readings. I would limit my bottom end measures to 16Hz.
Other than that, it looks like a legitimate graph of your response. You have a couple dips at 30Hz and 45Hz. You will have to attempt a few other positions to see if you can alleviate the problem - then decide if it makes sense to move the sub...
Old 06-11-08, 12:38 PM   #29 (Link)
Alias: David
User: #20731
Since: May 2008
htguy is offline
Thanks. So, because I have "dips" instead of "peaks," does this mean that I would not really benefit that much from an equalizer like the BFD? I read that EQ can not help much with a dip, but it can bring down the peaks. I do not have many options for the sub in my room. If moving the sub does not even out the curve, would it help to use the BFD to bring down the "peaks" at 36 and at 50? Would that allow me to better hear the entire range of frequencies from the sub?
Old 06-11-08, 01:36 PM   #30 (Link)
Alias: brucek
User: #6
You really need to do some placement tests with your sub to see if you can get a bit smoother response. Your response is going up and down through some dips and peaks, so you may be able to help it a lot with placement.
If you have a dip caused by an out of phase reflection, and so throwing some gain at that frequency will also increase the out of phase signal that's causing the problem. In that case you could add gain forever and you won't get rid of the dip. Moving the position a little might help though.
As long as you don't cut too much, and if you have the headroom to boost the sub back up, it would help.
Old 06-12-08, 01:45 AM   #31 (Link)
Alias: David
User: #20731
Since: May 2008
htguy is offline
I moved the sub a little, and that made virtually no difference. I only have two other places for the sub. One is in a corner, and the other is a few feet from that corner. Both graphs are attached. It seems like I have problems no matter where the sub goes. Would EQ fix one of these positions better than the others? Room treatments are not an option.
Thanks
Old 06-12-08, 05:54 AM   #32 (Link)
Alias: brucek
User: #6
The second plot is a bit better. Removing the peak at 36Hz would probably help out.
It would be a lot easier if you were to get REW working. Do you not have an old PC around?
Old 06-12-08, 10:27 AM   #33 (Link)
Alias: David
User: #20731
Since: May 2008
htguy is offline
I have been working on trying to fine someone who will let me borrow a PC for a while.
Thanks
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Did moving my couch make a difference? angryht REW Forum 9 04-18-08 10:23 PM
RL-P18 D4 or D2? Any difference in SQ atm98 SoundSplinter 3 11-30-07 04:23 PM
Speaker cables that "really" make a difference? Sonnie Remotes | Cables | Accessories 18 11-18-07 07:38 PM
Do "High End" Power Cables Make a Difference ? Marks57 Remotes | Cables | Accessories 36 09-09-07 06:00 PM
Do cables make a difference? Roger Home Theater, Audio and Video News 0 05-19-06 08:13 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
