BFD L & R engine as presets? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss BFD L & R engine as presets? in the Subwoofer Equalization | Calibration forum; BFD L & R engine as presets? Some people use Hifi integrateds to power their front L&R speakers, feeding them from their AV receivers pre outs. They ...
Old 08-21-06, 06:34 PM   #1 (Link)
Alias: Russell
Loc: Cambridge, UK
User: #494
russ.will is offline
Some people use Hifi integrateds to power their front L&R speakers, feeding them from their AV receivers pre outs. They do this to keep their CD/LP chain free from AV impurity.
The question is - If you have a sub without separate high and low level crossovers, can you feed the Left Engine the LFE channel, whilst feading the Right Engine a hifi pre-out signal. This would allow the hifi boys a suedo dual crossover arrangement as they could tailor filters to roll the sub in at say 30Hz because they're running their speakers full range. It would give you effectively two presets on the BFD - one for AV and one for Hifi.
Is this clear? Am I missing something really obvious?
Russell
Old 08-21-06, 09:53 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: BFD L & R engine as presets?
I'm afraid I don't know what this means. Could you explain?
I don't really understand the question, but if you're wondering if the BFD's two channels are completely discrete, the answer is yes..
Old 08-22-06, 03:07 AM   #3 (Link)
Alias: Russell
Loc: Cambridge, UK
User: #494
Sorry I'll clarify.
Some people (the mate I'm asking this on behalf of) have high quality 2 channel hifi. To maintain the quality of their stereo playback AND have 5.1 surround they power their center, surround left & surround right speakers from the AV amp, but take the front left & right output from the pre outs of their AV amp and feed it into a spare input on their stereo amp - treating it as a power amp for the purposes of AV.
The friend in question is looking into a BK Monolith DF sub (see Ilkka's test), but the problem is that it has high & low level inputs, high & low level gain controls, but only one crossover control. To save faffing around with the crossover control (and because he should be EQing anyway with a sub this size) I was wondering if the BFD as well as being used in the normal AV way, could use the spare engine to take a full range signal from the pre out of the stereo amp and then set up a set of filters on the spare engine. He'd then have an AV preset on one channel and another preset on the other channel.
Hope that's clearer, but your answer answers my question anyway.
Many Thanks
Russell
Old 08-22-06, 07:25 AM   #4 (Link)
Alias: brucek
User: #6
But wouldn't the signal that was split from the two channel system be stereo (two channel). How would you feed this to a single channel of a BFD without a combiner?
Or am I still not with it? I assume the term "stereo amp" means integrated amp.
Old 08-22-06, 05:32 PM   #5 (Link)
Alias: Russell
Loc: Cambridge, UK
User: #494
This is the sort of questioning I want to know. Stereo integrated amp, or stereo pre/pro, it makes no difference.
What would be the problems with combining the stereo signal from a hifi pre-amp into a single mono input ie, the reverse of a single phono to two phono splitter? I hadn't thought of this problem, or even if it is a problem.
Russell
Old 08-22-06, 06:39 PM   #6 (Link)
Alias: brucek
User: #6
Splitting a line level signal with a simple Y-splitter cable adapter is completely different from the reverse situation of combining two outputs into one mono signal.
If you used a Y-splitter cable adapter in reverse you would essentially be shorting the two outputs of the pre-amp together - a real no-no.....
The only way to properly do this would be to purchase a combiner specifically designed to carry out this task. You can build your own from passive components, but it's not really desirable. An active device is required for proper isolation of the channels.
Old 08-22-06, 07:07 PM   #7 (Link)
Alias: edd
User: #2120
Since: Aug 2006
eddthompson is offline
or just get another bfd
or a deq2496, which im planning on experimenting with for my mains.
Old 08-22-06, 07:13 PM   #8 (Link)
Alias: Russell
Loc: Cambridge, UK
User: #494
brucek wrote: View Post
Russell
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
BFD 1124P Servo Balanced Inputs bellnm BFD Forum 14 08-24-06 03:44 PM
BFD, new condition, SPL meter option highcurrent Classifieds - Equalization and Calibration Equipment 16 06-21-06 08:59 PM
1st attempt with BFD... your comments? highcurrent REW Forum 8 05-07-06 03:03 PM
BFD Guide Quick Links | FAQ | Tips Sonnie BFD Forum 4 05-04-06 12:57 PM
BFD sub EQ with or without mains? Valorum BFD Forum 5 04-27-06 08:45 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
