H/K and BFD question - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss H/K and BFD question in the Subwoofer Equalization | Calibration forum; H/K and BFD question Hello, I'm new here I've got a fairly nasty room that I've decide to try and EQ on for the ...
Old 08-30-06, 08:01 AM   #1 (Link)
Alias: wmilas
Loc: Chicago, IL
User: #2221
Since: Aug 2006
wmilas is offline
Hello, I'm new here
I've got a fairly nasty room that I've decide to try and EQ on for the sub. I purchased a FBQ2496 that I'll be using after reading the help doc on the REW interface. The room is fairly large.. 25x25x10. It has no back wall as it opens to a bar area which opens to the kitchen.. so the room is actually about 70ish feet long.
I have an svs Ultra placed into a semi false corner.. its the lip that the bar sets up on. ITs in the "rear" of the room and helps a bit with bass extension. The room is all hardwood although I have a pad and rug on about 60% of the 25x25 area. A sofa and a few seating areas. I can't treat the room because of WAF. This is not my theatre room so I'm ok with that. I realize im not going to get HT thundering bass here.. I'm just looking for a bit of punch for music and when using the plasma for movies for the kids, and when guests are over.
Hence the BFD. My question is that the HK has a fairly good RoomEQ. It does a good job above say 200hz and not all that great below. I'd like to keep using it but I'm not sure how to integrate it with the BFD. Should I just turn the roomEQ off in teh HK? Shoudl I let the HK do its thing then set up my house curve on the BFD? I imagine setting up a house curve on the BFD first then roomEQing with the HK would destroy the house curve?
Any suggestions/experience with this?
Thanks in advance
Old 08-30-06, 08:14 AM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: H/K and BFD question
Yeah, that's what I would do.
Run the HK EQ with the BFD filters all off and then do an REW sweep to see how it looks.
Then use REW and the BFD to set filters to smooth the 15Hz to 200Hz area (and add a house curve if desired)...
Old 08-30-06, 08:21 AM   #3 (Link)
Alias: wmilas
Loc: Chicago, IL
User: #2221
Since: Aug 2006
wmilas is offline
Wow. That was fast. Thanks.
Now I just have to wait till friday and the UPS man
Old 08-30-06, 10:25 AM   #4 (Link)
Alias: wmilas
Loc: Chicago, IL
User: #2221
Since: Aug 2006
wmilas is offline
Question.. am I going to need some CleanBoxes to go from RCA->XLR or cause i just use a rca->14" converter? Reason I'm asking I know that XLR (pro) requires a high level signal than what home (rca) puts out... I'm not sure about on the 1/4" side though?
Help?
Old 08-30-06, 11:04 AM   #5 (Link)
Alias: brucek
User: #6
No, the BFD employs electronically servo-balanced inputs and outputs on its XLR and 1/4" TRS connectors.
This allows you to use regular RCA cables to and from the BFD by using RCA to 1/4" mono TS adapters like these:
Then simple use the level switch on the back of the BFD to switch from Pro levels of +4dBU to Consumer levels of -10dBV....
The hookup of the BFD (and REW if used) is as shown below:
It would be worth while reading the well written
REW Help Files
Old 08-30-06, 11:25 AM   #6 (Link)
Alias: wmilas
Loc: Chicago, IL
User: #2221
Since: Aug 2006
wmilas is offline
I read the help files. I didnt catch the part where the BFD has a switch that lets you set the input voltages. That was the real meat of my question, which you more than covered
Thanks much.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Question on building an RCA to 1/4 inch cable for the BFD? Greybeard191 BFD Forum 2 08-30-06 08:30 PM
BFD and REW question about hook up and calibration apilon REW Forum 8 08-08-06 11:55 AM
BFD Hookup Question rolyasm BFD Forum 13 07-22-06 12:08 PM
BFD Question 1100 vs 1124? gacole2000 BFD Forum 1 05-25-06 06:10 PM
BFD Question Newfiestang50 BFD Forum 13 05-15-06 07:18 PM
Mach 5 Audio
