Noise or HUM from BFD - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Noise or HUM from BFD in the Subwoofer Equalization | Calibration forum; Noise or HUM from BFD I am getting a humm or noise from the subwoofer with no inputs. This noise occurs with or without a ...
Old 10-08-06, 03:10 AM   #1 (Link)
Alias: rkruz
Loc: US
User: #2936
Since: Oct 2006
rkruz is offline
This noise occurs with or without a subwoofer input to the BFD.
The noise does not occur when I switch to another preset with factory defaults.
I have 7 filters in the 20 to 100 Hz band. Seems like it occurs with even 1 filter active.
I have turned off all filters and the noise goes away.
I have tried different cables including RCA and balanced with no change.
Both units are plugged into the same power outlet.
Sounds like processing noise is being output.
Is this a common problem? It would make the BFE unusable for me in my Home Theater.
Maybe I have too many filters running.
Any hints to try to improve the hum would be appreciated.
thanks again~!
Old 10-08-06, 07:04 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Noise or HUM from BFD
Doesn't sound like a ground loop, but to be sure you could use an AC cheater plug as a test.
If it is eliminated with the cheater, then there are safe solutions.
If the cheater doesn't work, then you have a faulty unit.
They generally make no perceivable noise at the sub frequency range..
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
What solution do folks use for the dreaded BFD hum? Mitch G BFD Forum 166 10-06-08 03:12 PM
Please help with hum in IB with BFD howburger BFD Forum 23 12-04-07 12:18 PM
Driver Noise derekbannatyne DIY Subwoofers 18 05-31-07 05:20 AM
Ground loop hum? jeffbridges BFD Forum 3 09-15-06 05:03 PM
The hum of frustration Snookboy BFD Forum 7 08-11-06 08:35 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
