Operating level button - ok to leave in "OUT" position (+4dBu STUDIO) setting? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Operating level button - ok to leave in "OUT" position (+4dBu STUDIO) setting? in the Subwoofer Equalization | Calibration forum; Operating level button - ok to leave in "OUT" position (+4dBu STUDIO) setting? Greetings! My setup is as follows: Sony 9000ES pre-amp feeding an 1124, which in turns feed a pair of Crown ...
Old 10-25-06, 07:51 AM   #1 (Link)
Alias: Peter
User: #2808
Since: Sep 2006
pclausen is offline
Greetings!
Sony 9000ES pre-amp feeding an 1124, which in turns feed a pair of Crown CE-2000, both if which are bridged and in turn feeding feed a pair of TC Sounds PA-5000 18" subs.
The 9000 also feeds an Adcom GFA-5500 connected to my mains (Klipsch KLF-30s) and an Adcom GFA-7500 connected to my 4 surrounds and center channel.
My issue is that when I crank up the volume on the pre-amp to just before the clipping LEDs on the 5500 come on (-18 dB on the pre-amp display), I have to use the +4dBu setting on the BFD and set the LFE out @ +2dB on the pre-amp to get the red 0dB LEDs on the BFD to clip on occasion.
If I use the -10dBu HOME setting on the BFD, I have to reduce the LFE out on the preamp to something like -12dB on the pre-amp.
Seems to me my levels are better matched by using the +4dBu setting.
Is this ok?
Thanks!
Peter
Old 10-25-06, 08:52 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Operating level button - ok to leave in "OUT" position (+4dBu STUDIO) setting?
Is this ok?
Yep. The switch simply adjusts the operating levels of the BFD.
Old 10-25-06, 11:58 AM   #3 (Link)
Alias: Peter
User: #2808
Since: Sep 2006
pclausen is offline
Great thanks. I just wanted to make sure since the BFG guide said to always use the "HOME" -10dB setting.
Old 10-25-06, 07:16 PM   #4 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
I noticed a few months ago on my BFD one channel was showing a few more leds than the other, I tested both subs and they measured the same SPL. One of my cables had pressed one of the buttons on the back of the BFD and changed it to the +4dBu setting, I changed it back to -10 and the leds for both channels matched again. The SPL readings for the sub in question did not change.
Old 10-25-06, 08:21 PM   #5 (Link)
Alias: brucek
User: #6
brucek is offline
That right, it only changes the operating range of the BFD.
Old 10-25-06, 10:55 PM   #6 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
pclausen wrote: View Post
I would set the LFE out @ 0 dB etc. Although the BFD doesn't clip right away, I wouldn't let the red LED lit, if you can avoid it.
Old 10-26-06, 03:46 PM   #7 (Link)
Alias: Peter
User: #2808
Since: Sep 2006
pclausen is offline
Right on. Thanks guys. Still learning the ins and outs of this 1124. I must say that a BFD is probably the most bang for the buck in audio I have seen in a while.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Input -level setting "approved DVDs"? Greybeard191 REW Forum 3 09-13-06 10:14 PM
No high-def "Live from the Red Carpet" this year HDBeat HD Programming 0 08-23-06 06:00 PM
Top Home Theater Websites Announce: "Its show time!" Wayde Home Theater, Audio and Video News 0 06-09-06 03:11 PM
Sony's STR-DG1000 "designed to optimize Blu-ray disc" Roger Home Theater, Audio and Video News 0 06-02-06 08:11 AM
"Highest level in the measurement is -49 dBFS" need help with REW union1411 REW Forum 5 05-12-06 04:55 AM
Mach 5 Audio
