2496 vs. 1124 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
2496 vs. 1124
Discuss 2496 vs. 1124 in the Subwoofer Equalization | Calibration forum; 2496 vs. 1124 I am about to buy a BFD. My reciever is a Yamaha 7.1 THX with optimizer setup. It equalizes down ...
Old 11-11-06, 07:46 PM   #1 (Link)
Alias: pwest
Loc: umbarger texas
User: #2976
Since: Oct 2006
pwest is offline
Question 2496 vs. 1124
I am about to buy a BFD. My reciever is a Yamaha 7.1 THX with optimizer setup. It equalizes down to 63 HZ. My crossover on the reciever is at 80 HZ. I have a velodyne CT-120 sub and a JBL E250P sub. Which BFD, would you recommend, and how would you set it up? Thanks, Phil
Old 11-11-06, 10:15 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: 2496 vs. 1124
The 1124 is your best bet since it has multiple programs. Some people use one program for movies and one for music.
If you co-locate both your subs in a corner you can get away with a single equalization. If not, then you'll have to equalize each one individually with the two channels.
Old 11-11-06, 10:34 PM   #3 (Link)
Loc: Lower Alabama
Re: 2496 vs. 1124
brucek wrote: View Post
That might actually depend on the room I think. In my fairly symmetrical room one sub is front right corner and another sub rear left corner... I'm able to eq with one channel and it worked very well. Same with both in opposite front corners. You can always try and see what happens.
Old 11-12-06, 05:35 AM   #4 (Link)
Alias: pwest
Loc: umbarger texas
User: #2976
Since: Oct 2006
pwest is offline
Re: 2496 vs. 1124
Hi Guys, Thanks for the advice. I will get the 1124. After I get one set up and download the room eq wizard,will I eq with the 1124 up to 63 hz where the yamaha takes over the eq process? Thanks pwest
Old 11-12-06, 06:44 AM   #5 (Link)
Alias: brucek
User: #6
Re: 2496 vs. 1124
We have some posters here that use auto systems and have had success with first running the receivers own auto-eq feature and then carry on and use the BFD for 20Hz to 200Hz. The trick is to not touch the auto system after that's done.
You'll have to see how it goes once you get REW working and take some nmeasurements. It's an impossible call to predict.
And don't get your hopes up that you'll be lucky like sonnie was with two subs.... two subs generally means two equalization channels....
Old 11-12-06, 10:49 AM   #6 (Link)
Alias: pwest
Loc: umbarger texas
User: #2976
Since: Oct 2006
pwest is offline
Re: 2496 vs. 1124
Thanks brucek, I have decided to get one bigger badder sub and try it alone. I am still researching my options before I buy. I know it needs to do 20hz or less, and 105db without clipping. I am leaning toward SVS or HSU passive, with maybe a QSC or Hafler pro amp. Thanks again, pwest
Old 11-12-06, 04:57 PM   #7 (Link)
Alias: brucek
User: #6
Re: 2496 vs. 1124
That's a really smart move. Both your subs, although fine, are both somewhat challenged below 25Hz. An SVS would be a huge improvement for you.....
Old 02-15-07, 02:40 PM   #8 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Re: 2496 vs. 1124
Sonnie wrote: View Post
Hey sonnie,
How much output do "both in opposite front corners" have over a single corner loaded sub? Didn't you have any phase cancellation problem?
Blaser
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
using the DEQ 2496 with rew, warning, mainly graphics. terry j REW Forum 12 11-09-06 06:12 AM
FBQ 2496 better performing then DSP1124? rkruz BFD Forum 1 10-10-06 09:35 AM
DEQ 2496 Patrick Nevin BFD Forum 2 09-24-06 10:53 PM
WTB: BFD 1124 and/or Calibrated Mic Otto Classifieds - Equalization and Calibration Equipment 2 07-21-06 11:27 PM
BFD Question 1100 vs 1124? gacole2000 BFD Forum 1 05-25-06 06:10 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
