Broken BFD - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Broken BFD
Discuss Broken BFD in the Subwoofer Equalization | Calibration forum; Broken BFD Hi guys. Due mainly to the information on this forum, I bought a BFD 1124 on eBay. Unfortunately, it appears ...
Old 11-20-06, 01:29 PM   #1 (Link)
Alias: BlueDude
User: #3165
Since: Oct 2006
Blue Dude is offline
Broken BFD
Hi guys.
Due mainly to the information on this forum, I bought a BFD 1124 on eBay. Unfortunately, it appears that only one channel works. Even with no input applied, the left channel is showing about half of the LED's lit and it outputs white noise. I have to assume that it's a defective unit so it's going back for exchange. Is that a good move, or did I uncover an "undocumented feature" of the unit? Factory reset had no effect.
Good news is that the right channel works fine and I was able to play with it some. I took my time making sure of good grounds on all my equipment and I experienced no hum at all using unbalanced connectors on the BFD. So when I get a replacement, I've got that going for me. I'm disappointed that I have to wait longer to set this unit up and run REW, but I'm looking forward to a different kind of "feedback" from this forum when the time comes.
Old 11-20-06, 10:41 PM   #2 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Re: Broken BFD
If all the connections at the back are OK and its not working take it back and get another one.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Broken T-nuts? derekbannatyne DIY Subwoofers 3 10-09-06 11:14 AM
My SPL meter might be broken... :( Exocer REW Forum 13 09-06-06 02:19 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
