On BFD 1124- Any way of adjusting below 20hz? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss On BFD 1124- Any way of adjusting below 20hz? in the Subwoofer Equalization | Calibration forum; On BFD 1124- Any way of adjusting below 20hz? Just wondering if there was a way to adjust below 20hz or is that limited by the BFD?...
Old 12-02-06, 12:00 PM   #1 (Link)
Alias: Bones
User: #2727
Since: Sep 2006
tdamocles is online now
Old 12-02-06, 12:10 PM   #2 (Link)
Alias: Vitez
User: #3781
Since: Nov 2006
Vitez is offline
Re: On BFD 1124- Any way of adjusting below 20hz?
I think if you boost below 20Hz you can easily destroy your sub. You also don't need to lower freq. below 20Hz since subs don't have much output that low...
Old 12-02-06, 12:34 PM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
The BFD doesn't limit the signal below 20Hz. It doesn't have any filters below 20Hz though. Many IB subs extend easily to 10hz, but equalization is a problem.
Old 12-02-06, 03:03 PM   #4 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
When EQing my IB, I boosted wide-band at 20 Hz, and then cut narrow band at 20 Hz and just above. This will work if you want to address a general hump/dip at <20 Hz. It's somewhat trial and error, but I was able to get decent results. What kind of sub are you using?
-- Otto
Old 12-02-06, 03:31 PM   #5 (Link)
Alias: brucek
User: #6
brucek is offline
But how much did you boost at 20Hz to get any effect at 10hz for example. Quite a bit I would guess.
Old 12-02-06, 03:57 PM   #6 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
Yeah, it was quite a bit. IIRC, I also kicked up my amp's gain quite a bit and then did a lot of cutting to hit my target.
-- Otto
Old 12-02-06, 04:45 PM   #7 (Link)
Loc: Lower Alabama
Sonnie is offline
I think this is one advantage of the BFD FBQ2496... where you can use a bandwidth of 120/60 at 20Hz. Of course you'd have to add a shelf filter at the appropriate frequency to eliminate any unnecessary boosting above 20Hz that the 120/60 filter will create.
Sonnie
Old 12-02-06, 05:24 PM   #8 (Link)
Alias: brucek
User: #6
brucek is offline
Does the FBQ have shelf filters?
The 1124 also allows up to 120/60 BW....
Old 12-02-06, 05:59 PM   #9 (Link)
Alias: Vitez
User: #3781
Since: Nov 2006
Vitez is offline
"bandwidth of 120/60 at 20Hz"
could any of you guys explain what this means?
IB subwoofer? Do you mean something like this:
http://white.hometheatertalk.com/tips/ib.htm
Old 12-02-06, 06:24 PM   #10 (Link)
Alias: brucek
User: #6
brucek is offline
bandwidth of 120/60
This is a filter width. You can set filters as low as 1/60th of an octave wide, up to 120/60 wide, which would be two octaves.
Yep. See our DIY subwoofer section for some discussion from members that have them..
Old 12-03-06, 01:11 AM   #11 (Link)
Loc: Lower Alabama
Sonnie is offline
Maybe I missed something somewhere... seems like there was something about the FBQ that made it more preferable than the DSP for IB's and for some reason I was thinking it was the BW.
I don't think it has a shelf filter, but you'd need something similar to what you've done in the past with the one filter stuck way up around 300Hz or so... maybe lower for this... I guess depending on what happens with the filter at 20Hz. It would be interesting to see some graphs on one.
Sonnie
Old 12-03-06, 01:51 AM   #12 (Link)
Alias: Bones
User: #2727
Since: Sep 2006
Sonnie wrote: View Post
If there are any more abbreviations my head is going to explode!
Old 12-03-06, 05:07 AM   #13 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
I'm using a 120/60 +16dB boost @ 20Hz with my IB using the 1124P. Several other filters at 10Hz steps 30Hz, 40Hz etc bring the inevitable hump above 20Hz back down to the target curve leaving the sub-20Hz boost almost untouched. I probably have an easy 100+dB (uncorrected RS SPL meter) capability at 10Hz if I was brave enough to try.
I see no excess cone movement suggestive of overdriving my AE IB15 drivers on any programme material tried so far. I take no responsibility for others destroying their subs (IB or not) in trying this extreme BFD filter setting. My IB has always needed to be driven hard to get any cone movement at all despite the very high SPLs I am getting.
Before and after graphs appear in my sig using the latest soft-look RS SPL meter and the REW correction file.
Old 12-03-06, 08:53 AM   #14 (Link)
Loc: Lower Alabama
Sonnie is offline
tdamocles wrote: View Post
Sorry bout that... the FBQ is the newer model BFD, the FBQ2496. The DSP is the older but more popular BFD, the DSP1124P. IB is Infinite Baffle subwoofer. BW is bandwidth as referred to in the BFD units.
Sonnie
Old 12-03-06, 03:12 PM   #15 (Link)
Alias: Bones
User: #2727
Since: Sep 2006
I thought it was kinda funny...I had a few chillies and happened to read that thread.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
2496 vs. 1124 pwest BFD Forum 7 02-15-07 02:40 PM
BFD 1124 & 24 filters: howto? fastleo63 BFD Forum 3 10-25-06 10:10 PM
Filters wont load to DSP 1124 rkruz REW Forum 4 10-08-06 11:46 AM
WTB: BFD 1124 and/or Calibrated Mic Otto Classifieds - Equalization and Calibration Equipment 2 07-21-06 11:27 PM
BFD Question 1100 vs 1124? gacole2000 BFD Forum 1 05-25-06 06:10 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
