BFD DSP1124P FIlter Chains - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss BFD DSP1124P FIlter Chains in the Subwoofer Equalization | Calibration forum; BFD DSP1124P FIlter Chains Has anyone thought about daisy-chaining the Left and Right channel filter sets on the 1124P to setup a 24 filter ...
Old 12-14-06, 02:11 AM   #1 (Link)
Alias: t35tB0t
User: #3908
Since: Nov 2006
t35tB0t is offline
Has anyone thought about daisy-chaining the Left and Right channel filter sets on the 1124P to setup a 24 filter EQ?
I know SNR will suffer with the double A/D conversion, but will it make a real difference? Note that the delay for a single channel is reported as a mere 1msec. So, the two channels daisy-chained will add a 2 msec delay. Not too bad?
Those extra equalizers might help with more complex room environments - ones with some notch-dropouts that need some narrow filter boosting. Finally, there is a lot of focus on getting our sub's responses smooth along a target line. What about the effect of all the equalization filters on phase?
When I built my satellites, I was extremely careful to setup both very flat response thru the cross-over as well as very very well match phase. It was quite a bit of work to get the first one right but it really made a difference. The human ear is very sensitive to phase - more so than level in some situations. My concern is that a wacky set of filters on the 1124P might generate a beautiful response curve insert horrible phase delay curve. Does this matter much below 100Hz?
Old 12-14-06, 10:01 AM   #2 (Link)
Moderator Emeritus
Alias: Naut
Loc: Richmond, VA
Ayreonaut's Avatar
User: #203
Ayreonaut is offline
Re: BFD DSP1124P FIlter Chains
t35tB0t wrote: View Post
1. Those narrow notches are best left alone.
2. You should really take measurements at all of the seating locations and design filters to correct the average response.
3. Don't worry about phase, worry about FR in a room full of standing waves.
Once you look at the average response, and forget about boosting at troughs you'll find that half a dozen filters is all that it really takes.
We are the Shack. Existence as you know it is over.
We will add your biological and technological distinctiveness to our own.
You will be mapped. Resistance is futile.
Old 12-14-06, 10:11 AM   #3 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Hi t35tB0t,
Yeah, chaining channel 1 to channel 2 on the BFD has been discussed and implemented by some. As Ayreonaut above indicates, it's usually not necessary to use that many filters, and you probably don't need to worry too much about narrow-band dips or humps.
As for the delay, the REW/BFD manual suggests adding an extra foot of distance to your pre/pro/receiver setup for distance to your sub. This will help account for the added delay incurred by the BFD's processing. I'd imagine that if you do any auto-setup, it will take that into account already since the BFD will be in place.
Of course, all the digital filtering will change the phase response of the signal. There is a medium-sized discussion about that around here somewhere. However, I'm not sure how much you will notice it. Most of us have focused on getting FR to where we like it, with a total disregard for phase. I not suggesting that disregarding phase is a bad thing, it's just the way it works out. I've considered measuring phase about the crossover points of my sub, but I have about 4,862 things that I have to do before I get to it.
Good luck.
-- Otto
Old 12-14-06, 10:31 AM   #4 (Link)
Moderator Emeritus
Alias: Naut
Loc: Richmond, VA
Ayreonaut's Avatar
User: #203
Otto wrote: View Post
You should adjust the distance or delay setting for your sub to minimize cancellation (maximize output) around the crossover frequency. The "phase" at that frequency is important.
Old 12-14-06, 11:05 AM   #5 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is offline
Ayreonaut wrote: View Post
Correct, I think that's a good empirical method to get it right. But if I had the time and energy, I'd like to see what's going on there as well.
-- Otto
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
DSP1124p loupy31 BFD Forum 9 06-16-06 08:46 AM
BFD filter help dongagon REW Forum 11 06-14-06 09:59 AM
The BFD DSP1124P | RS SPL Meter Giveaway Rules Sonnie BFD Forum 0 05-18-06 12:22 AM
Red blinking filter lights on BFD MisterG12 BFD Forum 3 05-12-06 12:00 AM
Apply filter - no sound - BFD jeffbridges BFD Forum 10 04-25-06 03:09 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
