Input Level -4/-5, ok? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Input Level -4/-5, ok? in the Subwoofer Equalization | Calibration forum; Input Level -4/-5, ok? Hello, just bought my PB12+ Connected the dsp1124p to my sr7500...and to sub. Putting in my WOTW disc, chapter 5. ...
Old 01-22-07, 02:26 AM   #1 (Link)
Alias: daxie
User: #4496
Since: Nov 2006
daxie is offline
Hello,
Bypass on BFD.
SW setting in receiver on 0.
Listening level at about -10 (about 85 dB, above normal listening level).
Play.
CLIP CLIP CLIP.
I had to turn it to -4 -5 with a listening level of 75dB not to make it clip all the way.
I even think it might need even 1 or 2 lower.
What do you think?
Can an input level be too low (since I will be needing to adjust it in my subamp). Or might there be behringer setting problem?
(The sensitivity button on the back of the bfd is pushed in, that's correct, isn't it?)
Thank you,
daxie
Old 01-22-07, 07:32 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Input Level -4/-5, ok?
I don't really know what input level you're talking about.
The switch on the rear of the BFD is a sensitivity switch which covers a fairly wide range of applications. With the button pushed in (-10dBV position), it will accept up to a maximum of +2dBV (about 1.25vRMS). This is consistent with most consumer equipment. The trim level control for subwoofer out on most consumer equipment allows for enough adjustment to match this spec.
When the switch on the rear of the BFD is out (+4dBu position), the sensitivity changes such that the maximum input level is +16dBu (about 4.9vRMS). This position usually accommodate pro equipment.
The voltage output of the subwoofer plug on a standard receiver will usually fall within the limits I've explained above. I looked at the manual of your receiver online and it does not list the output spec for the preamp section. The extent of their technical spec is confined to telling us how many outputs it provides - sheesh. I suspect it's fairly standard though...
Old 01-22-07, 08:51 AM   #3 (Link)
Alias: daxie
User: #4496
Since: Nov 2006
daxie is offline
I mean the input level to the BFD... = output level receiver ~ subwoofer setting in receiver...
I was just wondering if the fact I have to turn it down a lot is "abnormal"...
Thnx
Old 01-22-07, 09:45 AM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Not at all. That's why they provide the adjustment..............
Old 01-22-07, 11:49 AM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Basically, you need to adjust the receiver’s subwoofer output so that the BFD is just below clipping with most demanding passages from a movie like WOTW, played at the highest levels you expect to use (although it’s okay to occasionally hit clipping). After you equalize, however, it may be necessary to re-adjust the level.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Problem settings input level in REW Julien43 REW Forum 8 12-20-06 11:47 PM
? on Setting the input level on BFD kryolla BFD Forum 5 11-01-06 08:44 PM
Input -level setting "approved DVDs"? Greybeard191 REW Forum 3 09-13-06 10:14 PM
input level, and roll off eddthompson REW Forum 9 08-23-06 07:10 PM
Input Level Warnings rsachs REW Forum 1 08-05-06 05:32 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
