| BFD Forum Newbie question for SPL advice & 1124psDiscuss Newbie question for SPL advice & 1124ps in the Subwoofer Equalization | Calibration forum; Newbie question for SPL advice & 1124ps Hi all,
I am new to this forum for room sub tweaking. After reading some of the postings here I ... |
| | #1 (Link) | |||
| Newbie question for SPL advice & 1124ps Hi all, I am new to this forum for room sub tweaking. After reading some of the postings here I am ready to buy the H/W required for my stereo sub eq/ room treatment project. I would appreciate if some of you who has experience and knowledge can help me out: 1. I am thinking of getting a used SPL. Should I look for the analog or digital one from RS ? Any particular model should I look for ? RS33-2055, RS-33-4055 or RS33-205 ? Any issues or pluses that I should chose any particular model over the other one ? Can they have triport thread for support ? What about other RS OEM SPL ? EBay has lots of diff. brand which looks quite similar to the RS, any suggestion on those ? Can they be compensated with the C-weighted values provided by this site ? 2. I assume I need a USB external sound card for my laptop to run and record the measurement. Any particular one should I use ? SB live 24bit ? Is there any SB model that can serve the purpose for this in a smaller budget plus I can use it with my midi keyboard controller in a ocassion base ? 3. I bought a used BDF1124PS used from ebay and now I notice there is a new firmware 1.4 availabe. What are the fixes for this new firmware ? how critical it is to the purpose of sub eq for my Stereo subwoofers ? Is it critical to update it ? Many thanks in advance.. | |||
| | #2 (Link) | ||||||
| | Re: Newbie question for SPL advice & 1124ps Quote:
Hope this helps. Regards, Wayne | ||||||
| | #3 (Link) | ||||
Read this thread about some meter problems and then decide if you want a used RS Meter. Either get a new one or a Galaxy CM-140 or the (Behringer ECM8000 with a preamp). brucek | ||||
| | #4 (Link) | |||
| Re: Newbie question for SPL advice & 1124ps Hi Brucek, Sound like there are lots of problem witht he RS SPL out there.. If I go for the BEH ECM8000, does it work with any more economic preamp than the Yenyx 802 preamp ? I don't need any mixer all I need is to connect it to the sound board. Any suggestion of what other choice of preamp will work ? Will some ART mic preamp will work with ECM8000 ? Thanks again ! | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Question about digital RS SPL meters | Greybeard191 | SPL Meters | Mic's | Calibration | Sound Cards | 2 | 08-04-06 04:17 PM |
| Hi Everyone Another Newbie Here | 11B2P | Welcome | Member Introduction | 2 | 07-21-06 12:50 AM |
| Another connection question - M-audio 410 & SPDIF | maneuen | REW Forum | 8 | 07-18-06 09:08 AM |
| Newbie question connecting sound card | purcellt | REW Forum | 2 | 07-17-06 07:10 AM |
| Noob question on RS SPL | sammythebu11 | REW Forum | 4 | 07-10-06 05:40 PM |
