Red blinking filter lights on BFD - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Red blinking filter lights on BFD in the Subwoofer Equalization | Calibration forum; Red blinking filter lights on BFD Man I can win When I plug in and turn on the BFD I get a constant red blinking lights ...
Old 05-11-06, 06:55 PM   #1 (Link)
Alias: Matt
User: #414
MisterG12 is offline
Man I can win
When I plug in and turn on the BFD I get a constant red blinking lights on all 12 filters left and right. If I spin the jog dial to 1 all lights blink. If I spin it to two 1, 2 and 3 are solid red while 4-12 blink, spin it to 3 and 4-12 on the right blink while 5 through 12 on left blink
This does this if its just plugged into the wall with no conections or ran between my pre/pro and sub
Why might it be doing this?
Matt
Old 05-11-06, 09:43 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Red blinking filter lights on BFD
Set each of the 12 filters in your program to "OF" and the blinking will stop.
Then enable each filter you use to "PA" when it's added.
Old 05-11-06, 10:01 PM   #3 (Link)
Alias: Matt
User: #414
Bruce/Sonnie
Man thank you so much. You truly have helped me out alot today! If there is anything I can do to help either of let me know.
What a fantastic place this is.
Matt
Old 05-12-06, 12:00 AM   #4 (Link)
Loc: Lower Alabama
Sonnie is offline
brucek said it so much easier than I did.
You can help... invite others in to join us!
I am glad you got that resolved though.
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
