BFD - Is it worth it? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss BFD - Is it worth it? in the Subwoofer Equalization | Calibration forum; BFD - Is it worth it? Is it worth it to get a BFD....
Old 02-11-07, 10:28 PM   #1 (Link)
Alias: gil
Loc: princeton, nj
User: #6437
gilbypoleadamson is offline
Question BFD - Is it worth it?
Old 02-11-07, 11:16 PM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: BFD - Is it worth it?
It depends on your sub response in your room... it's definitely worth it if you need it. The best way to determine if you need one is to use REW and take some measurements of your sub-only response. It's likely you can use one, but I've seen a few that didn't need one and I could do without one myself if I wanted to.
Old 02-12-07, 04:12 PM   #3 (Link)
Alias: Mitch
Loc: Naperville, Illinois
User: #2469
Since: Sep 2006
Mitch G is offline
And, you may be able to find the 1124 for a good price on ebay - that's where I got mine for $70 to the door. Well worth it in my case.
Mitch
Old 02-13-07, 06:55 PM   #4 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
I just got one too off ebay, NIB $72 that includes shipping also.
Old 02-15-07, 12:19 PM   #5 (Link)
Alias: Bob
Loc: Lytham-St-Annes, UK
Malice's Avatar
User: #304
Malice is offline
I couldn't do without my BFD as I have some severe mode problems at 28Hz and 32Hz. Up to 15db hotter than "Normal" which makes it sound boomy. BFD tamed the sucker, with some advice by BruceK and Dr Who on this veritable forum.
| Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant|
Bob - "Malice" was my Quake 2 CTF name
Old 02-15-07, 11:16 PM   #6 (Link)
Alias: lovingdvd
User: #5942
Since: Jan 2007
lovingdvd is offline
Yes I HIGHLY recommend BFD and REW. Before getting started with it I new nothing at all about sub eq or even the need for it! I discovered the need after I bought a new sub and found it sound "all over the place" just like my old sub. Suddenly at that point I realized my old sub wasn't horrible, but rather, that something was wrong with the room. After doing some digging I found my way here and after a few weeks of some pretty intensive learning, I was all set with awesome sounding bass. It has truly transformed my HT!
Here's a quick and dirty test you can do to see if you could benefit from sub eq. Take a radio shack sound meter and sit in your normal listening position. Play a sub pink noise tone - any will do - and set your volume on the receiver to about 75db.
Now play a low bass frequency sweep (say 20-100hz). Watch your sound meter as it plays. If the needle stays pretty much around the same point then you are good to go (highly doubtful!). Instead you'll likely find the meter flops all over the place like a fish out of water - pinning itself at some points and falling off at others, and then back again. This my friend is how you KNOW you need to dig in here and get started with REW and BFD!
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
TiVo Series3: Worth $800? HDBeat Home Theater, Audio and Video News 0 09-06-06 02:00 PM
Omnimount unleashes stylish new AV furniture designed to handle up to 18 stones worth of kit - including 60in screens Roger Home Theater, Audio and Video News 0 05-15-06 08:12 AM
HD DVD it is truely worth it! bobgpsr High Definition | HD DVD | Blu-ray 5 05-06-06 12:33 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
