Question about BFD 1124p filter ? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss Question about BFD 1124p filter ? in the Subwoofer Equalization | Calibration forum; Question about BFD 1124p filter ? My question is simple. I know that the DSP 1124p features 24 filters, i.e 12 filters per channel. Then I ...
Old 03-26-07, 05:43 PM   #1 (Link)
New Member
Alias: mic-el
Loc: Canada
User: #7402
Since: Mar 2007
mic-el is offline
Then I to use the 24 filters at the same time, i.e the 2 channel together ? If yes, How do that.
Another question : It is necessary to put my amplifier filter at 200 for made a EQ sub ?
Thank you and sorry for my english !:raped:
Old 03-26-07, 06:31 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Question about BFD 1124p filter ?
To use 24 filters, connect the output of channel 1 to the input of channel 2 with a cable that has 1/4" TRS connectors at each end.....
Then your input to the BFD is channel 1 and the output is channel 2.
Never seen anyone actually require more than 12 filters for any equalization of a subwoofer.
I presume you are asking if you should bypass the subwoofers own crossover control when you use the bass management of your receiver? The answer to that would be yes, dial it as high as it will go so the croosver won't interfere with the receivers crossover.
The BFD EQ is only used to eliminate peaks and dips in the bass response.
Old 03-27-07, 07:08 PM   #3 (Link)
Alias: Phil
Loc: Idaho
allredp's Avatar
User: #6382
allredp is offline
brucek wrote: View Post
Just to clarify for a newb--I should disengage (if that is an option) my sub's x-over, and have only the AVR x-over active, right?
Thanks,
Phil
Dali Mentor 8/Vokal/Ikon Phantom 5.1; SVS pb13 Ultra; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Heaven!
Now about that projector...
Old 03-27-07, 07:13 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Correct...
Old 03-27-07, 08:05 PM   #5 (Link)
New Member
Alias: mic-el
Loc: Canada
User: #7402
Since: Mar 2007
mic-el is offline
thank you very much !
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
Filter Question aceinc REW Forum 10 03-22-07 07:27 AM
SVS Sub-Sonic filter setting question stevefish69 SVSound 7 02-10-07 03:03 PM
FS: BFD 1124p + RS Meter Sonnie Classifieds - Equalization and Calibration Equipment 5 01-15-07 07:27 PM
FS: BFD 1124p + RS Meter Sonnie BFD Forum 4 10-02-06 06:52 PM
BFD filter help dongagon REW Forum 11 06-14-06 09:59 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
