| BFD Forum Wondering about BFD and biwiring...Discuss Wondering about BFD and biwiring... in the Subwoofer Equalization | Calibration forum; Wondering about BFD and biwiring... I was reading this article at the Harman Kardon site and when reading about the different bass response of each ... |
| | #1 (Link) | ||||
| Wondering about BFD and biwiring... I was reading this article at the Harman Kardon site and when reading about the different bass response of each speaker and how a sub woofer makes sense in such a setup, I then asked myself the following question, which I pose to you guys. Would it make sense to have a separate BFD unit to equalize the bass of bi-wired front speakers? I know it would probably not offer much of an improvement, and am also aware of digitizing the low end of a good pair of fronts (thus I thought about biwring and only having the BFD in there). But I also thought that it might give a smoother response around the crossover. It is just a theoretical question though I just got another BFD for a friend and I could test it out in a month or so. | ||||
| | #2 (Link) | ||||
| Re: Wondering about BFD and biwiring... Good morning Artemio, Not a bad idea, but I see a couple problems.
Too bad. I like the idea, and I'm set up with a bi-wire system right now. The difference the BFD makes for subs is so great that I really like the idea of processing the "bass" of my mains. Now, all that said, if you can get another BFD from a friend and see how it goes -- why not? It's not going to break anything, and you may like it! Let us know how it goes... -- Otto | ||||
| | #3 (Link) | ||||
| Re: Wondering about BFD and biwiring... Good morning Otto, thanks a lot for your reply. I did get carried away there, you are right it could not be done as I first rushed to think. I'd need to place it between the pre-amp and the amp, and then I would have both of the problems you describe unless I bi-amped. It seemed too good to be true, and there was more than one reason for that. Anyway, I might give it a try when the BFD arrives just to check it out. | ||||
| | #4 (Link) | |||||
| Re: Wondering about BFD and biwiring... Quote:
Regards, Wayne | |||||
