BFD Thanks - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
BFD Thanks
Discuss BFD Thanks in the Subwoofer Equalization | Calibration forum; BFD Thanks I finally got my backordered FBQ2496 a few days ago. I want to thank everyone here for the info and ...
Old 04-22-07, 02:08 PM   #1 (Link)
New Member
Alias: jmps
Loc: chicago area
User: #6873
  jmps is offline
BFD Thanks
I finally got my backordered FBQ2496 a few days ago. I want to thank everyone here for the info and software. I needed to use this on my Hsu 2.3. I am SO happy with the results. I have a fairly problamatic room with some peaks around 30 Hz and 60 Hz that made the bass boomy sounding. The BFD has smoothed all that out and the bass is now tight and very musical (my goal).
I did get the 2496 for the extra headroom. I did not get the MIDI cable because of the extra cost and found entering the filters in directly a snap.
Once again a BIG THANKS!
Old 04-23-07, 06:21 PM   #2 (Link)
Bronze Supporter
Alias: Julien
Loc: Western NC
User: #4401
Since: Nov 2006
  Julien43 is offline
Re: BFD Thanks
"The BFD has smoothed all that out and the bass is now tight and very musical (my goal)."
It's alway great to hear when everything works out!
I'm still in the process of optimizing my room with the help of REW.
Once I achieve the best I can, within my limitations, I will go after those low freq room modes that are so hard to beat into submission using room treatments.
(my room really sucks)
Thanks for sharing your results
Julien
Old 04-26-07, 02:28 PM   #3 (Link)
New Member
Alias: jmps
Loc: chicago area
User: #6873
  jmps is offline
Re: BFD Thanks
Julien,
When you are done you will be so much happier. I am so glad for this forum to help with this issue.
Regards
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227
