BFD'ing subs with built in PEQs ? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > BFD Forum
BFD Forum
Discuss BFD'ing subs with built in PEQs ? in the Subwoofer Equalization | Calibration forum; BFD'ing subs with built in PEQs ? I have dual PB12+2/s that I'm about to use a new BFD on. I say about to because when I ...
Old 04-20-07, 08:15 AM   #1 (Link)
Alias: Schwingding
Loc: Glen Arm, MD
User: #5949
Since: Jan 2007
  Schwingding is offline
I have dual PB12+2/s that I'm about to use a new BFD on. I say about to because when I plugged it in to my subs - I got a hum which I was prepared for due to the excellent reading material here on this site. (gotta go buy a cheater plug)
My subs are stacked on top of each other.
So I spent last evening examining the filtering aspects of REW in preparation. NEAT! REW suggests 6 filters for my response curve. The most egregarious aspect of my response curve is a very wide peak from 14-20Hz of about 8db.
I was able to use the onboard PEQs on my subs to flatten out that particular peak very nicely.
My question is - is there any preference for using the BFD for all filters? If not, is there any preferred order to adjust them? For example, I could first flatten out the curve with the BFD and use the onboard PEQs to handle any leftover peaks, or I could first flatten a couple of peaks with the onboard PEQs and use the BFD to tame the rest. I'm guessing the answer is "doesn't matter", but can't hurt to ask.
Thanks.
Old 04-20-07, 10:03 AM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: BFD'ing subs with built in PEQs ?
Schwingding wrote: View Post
Umm, no. You should figure out what’s causing the ground loop and fix it. First place to check: your cable TV or satellite antenna feed.
If you have the BFD, there’s no good reason to use the sub’s on-board PEQ. Not to mention, it’s much more difficult to use, since it’s hard to precisely determine the frequency, bandwidth and gain factors.
Wayne.
Old 04-20-07, 10:10 AM   #3 (Link)
Alias: Schwingding
Loc: Glen Arm, MD
User: #5949
Since: Jan 2007
Oh I know whats causing it. It is because the location of the subs has required me to (temporarily) power them from one of my non-dedicated circuits for my HT. I have 3 dedicated 20 amp circuits run to my basement for my gear, but the best location for the subs, sound wise, has them in a corner where I didn't place juice from any of those circuits. The solution is to run a line over there, but there's a timeline involved.
BTW, the PEQs on those subs - I don't find them at all hard to use. I have a trick. I use the TrueRTA real time analyzer to find the exact frequency and Q factors. I can watch the screen change as I adjust the peq controls, no guesswork needed.
Thanks for your response!
Old 04-20-07, 10:52 AM   #4 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
That’s not a trick – that’s cheating!
Seriously though, an RTA is indeed the best and quickest way to set a parametric, especially an analog one. I typically assume people don’t have one unless they say so! Especially when they cost money, and REW is free!
« Home Theater Shack > Subwoofer Equalization | Calibration > BFD Forum »
Similar Threads
How many of you built your own cables? Bent Remotes | Cables | Accessories 87 11-05-08 09:49 PM
First real measurement subs, subs+main, subs+main large frockc REW Forum 13 03-17-07 12:42 PM
Built in Stage Sub Questions kano32 SoundSplinter 4 11-10-06 04:01 PM
Anyone Built gear for their HT Danny General Discussion 24 10-18-06 07:19 PM
Was the PS3 CPU Built for Gamers? Wayde Home Theater, Audio and Video News 1 06-26-06 07:13 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227
